All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-09-2006, 09:35 AM
busterstratton busterstratton is offline
Default
hello glad to have found this board I need some help I want to use a battery that is 12 volts to power a 6 volt light that has a rechargable battery(naturally also 6 volts).
This battery (deep cycle marine) is also used to power our automatic gate opener and is charged through both a 12volt solar panel and a 300 ft run of 16 gauge low voltage wire from the shed
I want to build a circuitboard that will supply the 6 volts to the light and also electrically trip to come on only when the gate is under power please help thank you
  #2
Old 06-09-2006, 11:29 PM
Gadget Gadget is offline
Send a message via MSN to Gadget
Default
As the whole system is solar powered, then obviously efficiency is a concern. Instead of a simple linear regulator I would suggest a basic PWM system. If you remove the 6 volt battery and charging circuit from the light then its only powering a light, so exact regulation isn't important.
I would suggest a 555 timer supplying a 50/50 squarewave at several kHz to drive a MOSFET, in turn driving the lamp. This will halve the voltage without wasting very much power in the conversion.
Powering this from the relay contacts that drive the gate motor should be all that is needed to ensure that it only works when the gate motor is working and doesn't draw any standby current when not operating.
Now, heres an even more revolutionaty idea......
Remove the electronics and battery from the 6 volt light. Replace the bulb with a 12 volt bulb. Power it directly from the relay output to the motor.
Cant get much more efficient or simpler than that.
  #3
Old 06-10-2006, 12:30 PM
Default
0k gadget I had exactly the same plan earlier but would like to run the 6 volt light off off the relay only need something in the circuit to drop the voltage going to the 6 volt light. Thought mabey a zenner would do just that so that the voltage would go positive to the zenner at 12 volts then 6volts out of the zenner to the light, viola is this not possible???
Just looking for as simple a circuit as possible (not much maintainance that way).The gate has an aux circuit for the purpose of lights but it is 12 volts and thats why this post exists just need the voltage comming from the relay to drop to 6 volts as simply as possible thank you
  #4
Old 06-11-2006, 05:02 AM
Default
Not that simple, and like I say, a Linear regulator will waste as much power as it regulates..(6 volts @ "x" amps in lamps, same again in waste heat across the linear regulator)
What wattage is the lamp... ? A Zener wont do without a series pass transistor...(again a Linear regulator)
I still recommend replacing the 6v bulb with a 12 volt bulb. Simple, cheap, and 50% of the power isn't being wasted. Is there a good reason why this cant be done..?
  #5
Old 06-13-2006, 09:04 AM
Default
ok will replace 6 volt lamp with 12 volt halogen hope not to melt down the reflector thanks gadget thought it would be a simple fix but will listen to you for that is why i am here thanks very much , Buster
  #6
Old 06-14-2006, 06:00 AM
Default
If you use a 12v bulb of the same type with same or similar wattage, then it should run at a similar temperature.
  #7
Old 06-15-2006, 06:31 AM
radiosmoke radiosmoke is offline
Junior Member
Default
You could use two 6volt bulbs in series, just keep the one bulb in the reflector and add another reflector or just hang it in a box.
  #8
Old 07-01-2006, 06:03 AM
mrmeval mrmeval is offline
Default
Buck regulator is one. http://www.powerdesigners.com/InfoWe...converter.shtm
Tags
Related Site Pages
Section Title
Worksheet Boolean algebra
Worksheet Latch circuits
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Bipolar junction transistors as switches
Worksheet Batteries
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook 555 Schmitt Trigger : 555 Timer Circuits
Textbook Junction field-effect transistors : Solid-state Device Theory
Textbook Battery ratings : Batteries And Power Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
Simple Voltage Regulator and Wiring Question geratheg General Electronics Chat 9 07-12-2014 07:30 PM
Voltage Reduction Ericvic General Electronics Chat 5 11-06-2013 01:32 AM
DC Motor voltage reduction snizbatch The Projects Forum 8 07-17-2012 04:07 PM
operational amplifier and measuring voltage drop logearav Homework Help 11 08-24-2011 04:51 AM
Assessing an unknown transformer someonesdad General Electronics Chat 37 05-27-2010 05:22 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
