H-bridge motor driver need help here
ericyeoh
Joined Aug 2, 2009
58
Please take a look at this link,
http://www.robotroom.com/BipolarHBridge.html
If i exchange the Transistor of PNP into NPN.
The operation is change into
Forward
R1= GND, R2= Vcc, R3= VCc ,R4 =Gnd
Reverse
R1= Vcc, R2= Gnd, R3= Gnd ,R4 =Vcc
The problem, i facing at this moment is that when the transistor is on, The transistor cannot endurance for long period due to the heat. The transistor that i been using in the circuit is NPN(2N2222A). The resistor connect to the each of the Transistor is 1k ohm.
The Voltage supply to this circuit i use is 5V, the input volatge to each transistor also 5v(when need it).
But i exchange the resistor into 100 ohm to each Transistor(base), it seems to be last long a bit, but also cannot endurance for long period, the transistor will heat up and burn....
I need help here. please reply the solution step by step tq.
Wendy
Joined Mar 24, 2008
23,421
Try posting a schematic, it will help with the explanation.
From what little I read, and think I understand, you don't quite understand saturation and why it is important. The two most efficient states for a transistor in digital mode is on and off. When a transistor is fully on (and is in common emitter mode, which is what is shown in the link you gave) it only drops around 0.1 Volts between Collector to Emitter. The other mode, Common Collector, which is what I think you are talking about, the CE drops 0.6. This can make a huge difference in heating.
We'll also need to know how you're driving them.
Check out my profile and AAC blogs, I think you'll find I have some background in the subject.
SgtWookie
Joined Jul 17, 2007
22,230
In other words, the PNP transistors need to stay PNP.
You cannot simply change them for NPN transistors and expect it to work.
ericyeoh
Joined Aug 2, 2009
58
Actaully it can work, but it cannot last long due to the heat.
I'm using PIC microcontroller to drive it.
The input of each (base)transistor is control by the output of PIC microcontroller, the PIC microcontroller output is rather 5v.
SgtWookie
Joined Jul 17, 2007
22,230
OK, so if you replace the upper transistors with 2N2907 PNP transistors, your heating problem should be much reduced - but that also depends upon how much current your motor will draw when supplied with 5v.
bertus
Joined Apr 5, 2008
22,277
Did you read the contrilong part?
Controlling the H-Bridge Motor Driver
The resistors are the inputs that control the H-bridge. By connecting a resistor to either +VDC or GND,
it turns on or off the corresponding transistor. (+VDC is the positive end of the battery.
GND is the negative end of the battery.) When a particular pair of transistors is turned on, the motor does something.
Command : R1 , R2 , R3 , R4
Coast/Roll/Off: : GND or disconnected , +VDC or disconnected , GND or disconnected , +VDC or disconnected
Forward:GND or disconnected , GND , +VDC , +VDC or disconnected
Reverse:+VDC , +VDC or disconnected , GND or disconnected , GND
Brake/Slow Down:+VDC , +VDC or disconnected , +VDC , +VDC or disconnected
Since there are 4 resistors, there are actually sixteen possible ways this circuit can be commanded.
Don't sweat the other variations (they're in the book if you're curious). Except...
Never apply +VDC to R1 and GND to R2 at the same time! You'll short circuit the battery.
Never apply +VDC to R3 and GND to R4 at the same time! You'll short circuit the battery.
Next, let's build the H-bridge circuit using real parts...
Greetings,
Bertus
ericyeoh
Joined Aug 2, 2009
58
Well, original i use PNP transistor at R4 and R2, it works very well, there is no problem at all to the heating issue, but in order to connect to PIC to let it function, PIC never supply 0v or GND, it is just disconnencted or 5v.
To overcome this problem i change the design abit i try it by adding 2 NPN transistor to the base of the PNP transistor picture as shown below, this was advised by my friend.
but after i tried, the motor is not working and which ever supply 5v input to base (NPN)transistor is hot.
ericyeoh
Joined Aug 2, 2009
58
IF the motor is forward condition the current in the circuit it might look like this.
please tell me/say out if my theory is wrong!
And please tell me wheather this circuit can be work or not. It is just theoretical solution.
bertus
Joined Apr 5, 2008
22,277
If R4 is also high as in your schematic, the transistor on R6 will also be active.
The current will flow from the powersupply to ground, heating the transistors.
Greetings,
Bertus
jj_alukkas
Joined Jan 8, 2009
753
Your H-bridge needs inputs which is either High or low. It cant be floating. When you change transistors from PNP to NPN, the bridge enters a state in which either or both the inputs are floating, resulting in the heat and short circuit.
Wendy
Joined Mar 24, 2008
23,421
Actually it is worse than that. Even the transistion between levels can damage the transistors.
The H bridge is a digitial circuit, and connecting the inputs of the transistors is usually manditory. Generally circuit are added to prevent both transistors being on at the same time, a condition called shoot through. Sometimes some shoot through is unavoidable, but it is never good.
Case in point, this is a true H bridge, even though it is driving a speaker instead of a motor. The zeners try to prevent the transistors being on at the same time, and both transistors are off during the transistion from high to low, or visa versa.
Wendy
Joined Mar 24, 2008
23,421
BTW, those diodes (D1-4) don't really do anything for drive. They absorb back EMF spikes from the motor and prevent it from damaging the transistor. Otherwise they don't exist in the current paths.
The whole point of a H-Bridge is to turn one transistor (say Q1) on while the other is off (Q2). The other side can be inverted, but if it is on the same state then the motor (or speaker) gets no voltage at all.
SgtWookie
Joined Jul 17, 2007
22,230
The PIC should be able to source or sink up to 20mA per I/O pin, meaning that it can output nearly 5v (Vdd) or 0v (GND), except for the MCLR pin. There is also a total current source/sink limit; you will have to consult the datasheet for the particular PIC you are using to determine that.
jj_alukkas
Joined Jan 8, 2009
753
Is there any reason for you to not try an ordinary H-bridge? Build your H-bridge the way you can, then adapt the PIC's output for that as H-bridges give you only limited options for construction and connectivity whereas a PIC port can be adapted, inverted, amplified or switched.
hobbyist
Joined Aug 10, 2008
892
I don't think it will work because
Your 2 PNP driver transistors are connected from base to +Vcc through resistors R5 and R6 and the collector of your 2 inverters are connected to +Vcc. instead of to the base of your drivers.
If you put resistors between the collectors of the top 2N222 transistors and the +VCC then it would work to that point.
Or just connect the collectors directly to the base of there drivers.
That would work like an inverter than.
You have the proper concept just need to get the components in the right place
Here is a H-bridge driver of been breadboarding of late for my next robot project, see if you can use any ideas from this to get you on the right track.
.See if this helps. The Back EMF diodes are not in this schematic, but can be implemented as needed.
SgtWookie
Joined Jul 17, 2007
22,230
Aboamal,
Your circuit has no current limiting resistors for any of the bases. This will result in excessive current and a good deal of smoke.
Suitable current-limiting resistors would need to be inserted at nodes 1, 2, 5, and 7.
270 Ohms would be about right for nodes 1 and 2 (bases of Q5, Q6) if the drive source is a PIC with a Vdd of 5v.
A 2N3904 would be a limiting factor in saturating the TIP41/TIP42 pairs. A 2N2222 would be a significant improvement, just as available and about the same cost.
85 Ohms would be about right for nodes 5 and 7 (bases of Q1, Q2) for a Vcc of 30v. They would have to be rated for 15 Watts or more. If you stayed with the 2N3904, you'd need to use 270 Ohm resistors rated for 5w.
SgtWookie
Joined Jul 17, 2007
22,230
Hobbyist,
I'm afraid that the H-bridge circuit you posted would give very poor performance indeed.
You have 10 MEG resistors as pull-downs for the MOSFET gates, and 1 MEG resistors in the gate charge path. It would take a long time to charge the gates fully, and ten times as long to discharge them. While the MOSFET gate is slowly charging/discharging, the MOSFET will be operating in the linear region, and generating heat.
hobbyist
Joined Aug 10, 2008
892
Hobbyist,
Thankyou very much,
I'll have to look into that, and work with the data sheets, specs , ect... this will be a good excersise in designing with mosfets, great information about the capacitance, that's something I never knew about, this is a great forum to learn from.
Thanks again..
