All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-26-2009, 09:01 PM
hazim hazim is offline
Default Basic NPN transistor operation question..
I have learned in electronics courses about an NPN transistor is that current Ib controls Ic, the current Ic flows from c to e, and Ib flows from b to e.. how could the current pass from b to c (in NPN)?? I read this in an analysis for this circuit http://sub.allaboutcircuits.com/images/04090.png which is located here http://www.allaboutcircuits.com/vol_4/chpt_3/3.html and I'm taking about Q1
Hazim
  #2
Old 08-26-2009, 10:15 PM
mik3's Avatar
mik3 mik3 is offline
Default
Current can pass through the base-collector junction if the base is about 0.6V more positive than the collector. In normal operation of a NPN transistor you don't need to pass current through the b-c junction.
If you use collector as the emitter and the emitter as the collector, then current will pass through the c-b junction like as the b-e junction as normally. However, due to the different doping levels of the emitter and the collector (collector doping lower than the emitter) the characteristics of the transistor, like its gain, change.
  #3
kkazem kkazem is offline
Default Q1, NPN run backwards
Hi hazim,
At first glance, the circuit does seem strange, but if you follow the analysis from the 2nd link in your post, it's explained fairly well. I'll try to expand on that here to make it more understandable.
First, lets look at the case where the input is low. This is straightforward and the Q1 NPN get bias current thru the base-emitter junction in the normal manner, which sets Q2's base close to ground and much less than a diode drop above ground.
Now, back to the other case where the input is high. Note that Q1 is an NPN bipolar transistor. Therefore, as you would expect, there are three junctions: B to E, B to C, and C to E. Since Q1-E is above Q1-B, albeit not by much, but less than a diode drop, and Q1-C is a bit more than a diode drop above ground (thru the Q2 B-E junction) and much lower in voltage than Q1-B, and since the B-C junction is a P-N, just like the B-E junction, Q1-B to Q1-C will be forward biased and conduct the current from VCC thru R1 thru the Q1 Base to Collector junction and into Q2's Base to emitter junction, turning on Q2. The drop across Q1 Base to Collector should be in the area of 0.65V to 0.7V. In this case, with the current flowing from Q1-Base to Q1-Collector, Q1 is operating solely as a diode and not as a transistor. But when the input switch is grounded, Q1 is operating as a transistor.
I hope that explained it. Try this. Take an NPN transistor with a beta of about 100, perhaps a TO-92 size, and take a DMM that has a diode checker and put the plus lead to base and the minus lead to emitter and you'll read about 0.65 to 0.7V. Now, keeping the plus lead of the DMM on the base, move the DMM's minus lead to the Collector and you'll also read about 0.65V to 0.7V. It is a diode junction and operates this way in the circuit we've been talking about.
Good luck,
Kamran Kazem,
kkazem
  #4
Old 08-27-2009, 03:25 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
When an NPN is saturated (a normal mode of operation), current must flow from base to collector.
  #5
Old 08-27-2009, 10:04 AM
Default
Ok thank you all, I understood this issue well
  #6
Old 08-27-2009, 12:40 PM
vindicate vindicate is offline
Default
Quote:
Why would current flow from base to collector when saturated? I've read that before, and it doesn't seem to make sense to me. The only way that current flows from B to C is if B has a higher voltage that C. When the transistor is in saturation C is(usually) much higher than B.
  #7
Old 08-27-2009, 01:53 PM
rjenkins rjenkins is offline
Default
If any current flowed from collector to base in normal operation, the transistor would latch on and need the base actively pulled low to turn off.
That only happens under thermal runaway conditions, definitely NOT in normal use.
__________________
Robert Jenkins.
  #8
Old 08-27-2009, 01:57 PM
beenthere's Avatar
beenthere beenthere is offline
Default
You might find this section of the Ebook enlightening - http://www.allaboutcircuits.com/vol_3/chpt_4/3.html
The meter check of a transistor shows two PN junctions - BE & BC. If the BC junction is forward biased, then there will be current flow.
__________________
First comes the hardware, then the software.
  #9
Old 08-27-2009, 02:18 PM
Ron H's Avatar
E-book Developer
Default
Quote:
The base voltage is higher than the collector voltage during saturation of an NPN.
When a BJT is in saturation, Vce is typically less than 200mV, sometimes much less. Perhaps you are thinking of MOSFET saturation, where, unfortunately, the definition of saturation is basically the opposite for that of a BJT.
  #10
Old 08-27-2009, 03:50 PM
Default
Oh, sorry I didn't know you were talking about Vce, I thought you were talking about voltage at the collector, not the voltage dropped across it.
Tags
Related Site Pages
Section Title
Worksheet Bipolar junction transistor theory
Video Lecture Digital Applications - Transistors and Transistor Circuits
Video Lecture Transistor Biasing - Transistors and Transistor Circuits
Textbook Transistor ratings and packages : Bipolar Junction Transistors
Textbook Current mirrors : Bipolar Junction Transistors
Textbook The common-base amplifier : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Meter check of a transistor : Bipolar Junction Transistors
Textbook Introduction : Bipolar Junction Transistors
Textbook Bipolar junction transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question about NPN darlington pair transistor array sintau.tayua The Projects Forum 7 05-20-2009 05:52 AM
Basic Transistor Question... Seidleroni General Electronics Chat 18 12-14-2008 08:39 PM
Basic question on integer number input in c++ mentaaal Programmer's Corner 26 02-29-2008 06:02 AM
12 volt circuit really basic question obsessmuch The Projects Forum 4 04-16-2007 12:58 PM
Very basic question about reducing voltage kevinwilson The Projects Forum 2 01-14-2007 10:15 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
