Diode Clipper
zaidqais
Joined Feb 14, 2009
16
Hi Guys
I am studying electronics using the book ( electronic devices by floyd )
and i reached Diode Clipper but i didn't understand it very well
in the figure above i don't under stand why there is the 0.7 + volt in the positive part of Voltage out put (V out )
can you please explain it a little bit for me :)
Thank you
bertus
Joined Apr 5, 2008
22,277
Note that the backward voltage is also limited.
The diode will "breakdown" when the reverse voltage is higher than this breakdown voltage.
Just take a look at the attached datasheet for more terms used with diodes.
Greetings,
Bertus
Wendy
Joined Mar 24, 2008
23,421
Don't forget, there is another good electronics text book at this site. Sometimes it helps to come at it from different angle.
