All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-31-2006, 11:50 PM
mckaype mckaype is offline
Default
Hi People,
Newbie here with a question - I've got 6)ea 25A single phase (silicon) bridge rectifiers that are rated for 800V peak reverse voltage. They are model EGC5327.
I have a three phase variable voltage & frequency AC imput that will exceed the current rating of each of the rectifiers. I intend to parallel two rectifiers per phase.
Can somebody please help me out with a schematic that shows the connections?
Thanks much
Pete
  #2
Old 06-01-2006, 06:52 AM
n9352527 n9352527 is offline
Default
Something to think of: The forward drop voltages of diodes, even the ones that are of the same type, are not matched. Therefore the current through them would not be equally distributed when they are in parallel. Furthermore, the forward drop voltage also depends on the temperature, and the diode that carries more current would have a higher temperature resulting in lower forward drop voltage and in turn causing more current to flow through that diode instead of the other one. This might result in thermal runaway for one of the diode and a small bang.
It's like parallelling two BJTs without current sharing resistors. You could, of course, use current sharing resistors (one resistor each in series for each diode) if you want to spend some money to buy them and the small loss of power is not a problem for you. But I personally think buying a bigger rated diodes is the way to go.
Tags
Related Site Pages
Section Title
Worksheet Delta and Wye 3-phase circuits
Worksheet High-reliability circuits
Worksheet Multi-stage transistor amplifiers
Worksheet Basic AC-DC power supplies
Worksheet Rectifier circuits
Worksheet Rectifying diodes
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Rectifier/filter circuit : Discrete Semiconductor Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
The Distinction between Series and Parallel. studiot General Electronics Chat 7 02-08-2014 05:50 PM
Formulae for calculating resistor for LED in parallel rajat1684 General Electronics Chat 3 09-10-2013 07:00 PM
rectifiers Parallel input Ele General Electronics Chat 5 03-06-2010 08:26 PM
understanding capacitor ESR ratings DaveH General Electronics Chat 23 10-04-2009 02:46 PM
Wire in parallel: does strange things neuronet General Electronics Chat 6 06-29-2009 10:00 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
