All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-17-2009, 04:39 PM
lalalu lalalu is offline
Default sine wave shaper
Hello all
I am having trouble understanding a waveform shaping circuit that I found on the internet.
My task is to generate a sine wave (adjustable low frequency range). My plan is to use a vco to generate triangular wave and then change it into a sine wave. I was thinking of using the breakpoint method, and then I found this circuit.
So my question is what is the purpose of the opamp at the end? To smoothen the peak? or is this just aa normal feedback circuit. I also didnt get how the diodes work here, is this just a clipper circuit? I simulated the circuit in spice and found out that the circuit works just fine with only 2 diodes and 1 resistor (+side). Weird
Anyway I would appreciate it if someone could explain to me how the circuit work, or at least just the name of the circuit. Searching sine wave shaper blindly these past few days didnt yield much result. Thank you
  #2
Old 08-17-2009, 06:18 PM
jlcstrat jlcstrat is offline
Member
Default
It would appear the opamp is just used to amplify the signal...The diodes clip the signal to give it more of a sinusoidal shape...I'm only a student myself, but that would be my best guess
  #3
Old 08-17-2009, 07:20 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
The wave shape uses a kind of multiple break points to convert the triangle to a sinawave.
In the two attached PDF's you will find wave shapers with diodes too.
Greetings,
Bertus
File Type: pdf AN-263_sine_wave_generation_techniques.pdf (350.6 KB, 204 views)
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
The Following User Says Thank You to bertus For This Useful Post:
umarfarooqleo (03-28-2013)
  #4
Old 08-17-2009, 07:43 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Depending on your purity requirements you don't need a lot of circuits.
I was able to get this with two diodes and an op amp off a triangle wave.
Check this thread out.
http://forum.allaboutcircuits.com/sh...ad.php?t=12405
Nice links Bertus
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #5
Old 08-17-2009, 07:45 PM
Audioguru Audioguru is offline
Banned
Default
A ICL8038 and an XR2206 function generator IC uses multiple breakpoints with diodes to convert a triangle wave into a sine-wave with horrible distortion.
The circuit that has only three breakpoints is much worse.
  #6
Old 08-19-2009, 04:44 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
The eyeball is not a great harmonic distortion analyzer.
  #7
Old 08-19-2009, 08:58 AM
Default
Ok thanks guys for the speedy response. Especially Brutus .
The pdfs link helps a lot.
  #8
Old 08-20-2009, 12:19 AM
Super Moderator
Default
Quote:
Amen! Makes you appriciate HP equipment when you have access to it.
__________________
General info:
  #9
Old 08-20-2009, 01:09 AM
Banned
Default
You don't need an HP distortion analyser when the distortion is as high as the sine-wave made with a few breakpoints. You can hear the buzzing distortion.
  #10
Old 08-20-2009, 01:34 AM
Ron H's Avatar
E-book Developer
Default
Quote:
I was thinking more about the sine-like shape. All that golders is not glist, etc.
Tags
Related Site Pages
Section Title
Worksheet Design Project: Signal generator
Worksheet Mixed-frequency signals
Textbook Power quality measurement : Ac Metering Circuits
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Textbook Harmonics in polyphase power systems : Polyphase Ac Circuits
Textbook More on spectrum analysis : Mixed-frequency Ac Signals
Textbook Other waveshapes : Mixed-frequency Ac Signals
Textbook Square wave signals : Mixed-frequency Ac Signals
Textbook Introduction : Mixed-frequency Ac Signals
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC sine wave to DC square wave, newb, saw a similar thread SpeedEuphoria General Electronics Chat 11 05-01-2010 12:28 AM
Square wave to sine wave JBmtk General Electronics Chat 4 07-15-2009 05:14 PM
triangular to sine wave kahafeez The Projects Forum 13 12-16-2008 07:27 PM
changing a modified sine wave to true sine wave using simulink hyde6666 The Projects Forum 0 07-15-2008 06:35 PM
sine wave in a spectrum analyzer Polgi-Wan General Electronics Chat 3 02-19-2007 05:04 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
