I Did it at last. It took me some months to complete this simple-looking circuit.
I had 6 3-wire 120mm fans in stock and did not know how to use them. Now i have already order some more
I wanted to have a PWM rpm fan controller along with rpm feedback from the fan. Believe me, when you PWM the fan you get in troubles doing it.
The i 'altered' the original idea a little bit more, and converted the PWM generator into a simple variable power supply:
http://pcbheaven.com/circuitpages/PWM_Fan_controller_using_a_555
It did work but it was just NOT a pure PWM fan controller.
No more talking. I present to you my PWM masterpiece:
http://pcbheaven.com/circuitpages/Two_Speed_Temperature_Fan_Controller
This is a real PURE PWM fan controller and it does MUCH much more:
I spent an enormous amount of time to make it work and feel prod of it. Looks easy but believe me, it is not.
Thank you, and sorry for this rather pointless message. I just feel the flame inside me burning
- It uses simple DC 3-wire fans
- It uses PURE PWM pulses to rotate the fan
- It can achieve speeds as low as 600rpm without staling
- The fan sends rpm feedback to the controller
- The feedback can be used for rpm indication (easily)
- The feedback IS used to check the speed of the fan. If the speed is NOT within the +-10rpm limit, the controller automatically micro-adjust the duty cycle of the PWM
