I have been playing around with the experiments on here and have successfully built the power supply with a transformer robbed from an old turntable. I have also completed the rectifier projects. I would like to build a permanent power supply using the bridge rectifier and filter capacitor experiment but thought it might be beneficial to be able to switch between 6 and 12 volts as well as AC or DC. I have attached a drawing. My initial concern is the use of a filter capactior in conjunction with center tap rectification. Can this be done? Also, will the bridge rectifier work in this capacity (center tap rectification)? The main purpose of this power supply will be the later projects which call for 6 and 12 volt batteries.
