All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-04-2009, 10:57 PM
electrocub electrocub is offline
Default LED current indicator
I am building the circuit below to charge 12 volt SLA batteries. I would like an indication of what the circuit is doing. I have a 12 volt comparitor circuit I can hook to the battery to see what the voltage reading is. What I am looking for is a circuit containing a led that would be in series with the battery so I can tell when the current goes from high to low. Would a mosfet work? Could I use a logic chip? What are some of your thoughts? Thanks.
CJ
Flashing battery monitor Source: circuitstoday.com
  #2
Old 08-04-2009, 11:34 PM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
You didn't include a link to the project.
  #3
Old 08-05-2009, 01:21 AM
Default Sorry, try this link.
http://www.circuitstoday.com/battery...it-using-lm317
  #4
Old 08-05-2009, 02:13 AM
k7elp60 k7elp60 is offline
Default LM317 battery charger
Here is a link to a battery charger I build using the LM317T.
http://forums.qrz.com/showthread.php...attery+charger
I use a dual op amp as a comparator to monitor the charge current and turn on an LED when the current drops to a set level.
It may give you some ideas.
  #5
Old 08-05-2009, 02:44 AM
Default Thanks
Thank you. In my search for a battery charger, I saw your circuit, but missed the led. If I wanted to dress it up a bit, instead of the resistor and led, I could turn on a 555 with a flasher or do about anything I wanted to with the output couldn't I? Put a flip flop so when it was high, one led would light, then low, another? Thanks again. I am very much an amateur, but enjoy it so much.
Carroll
Tags
Related Site Pages
Section Title
Video Lecture RC Time Constants (Part 1) - Pulse Circuit Response - Inductors,Capacitors,Transformers
Worksheet Basic AC-DC power supplies
Worksheet Basic troubleshooting strategies
Worksheet Batteries
Video Lecture Electrical Quantities A - Basic Electronics and Units of Measure
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Voltmeter usage : Basic Concepts And Test Equipment
Textbook Battery ratings : Batteries And Power Systems
Textbook Ammeter design : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
LED constant current source: Part II? doug3460 The Projects Forum 12 06-08-2009 12:40 PM
opamp current direction in e-book swty_todd General Electronics Chat 62 04-02-2009 11:18 PM
Current limiting resistor for led on 7408 gate output laguna92651 General Electronics Chat 6 09-12-2008 05:59 PM
Another Solar Charger/Light Project iONic The Projects Forum 2 08-10-2008 12:34 AM
A bit of a silly question, LED current limiting resistor scubasteve_911 General Electronics Chat 11 01-04-2008 12:52 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
