All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 08-04-2009, 04:25 AM
jbjb jbjb is offline
Default LM741 voltage follower circut
Hello all
I've been working on a simple voltage follower circuit that will be used to protect an analog output on a data acquisition/output board that is connected to a computer. The voltage follower will go between the analog output and will drive a single LED. I planned to vary the outputted voltage to vary the current that goes through the LED.
Even though this circuit is really simple, it hasn't been behaving as it should. Two problems I've had with it are:
The Op amp is still drawing current from the source, even though it should have a nearly infinite input impedance. The current it draws from the source is about the same amount of current that the LED is receiving.
What gives?
This problem has been super frustrating because it should be so simple. I've tried building the circuit in different ways and am not sure if I've fried something or not.
I've attached my schematic. The op amp is powered by one 9V battery. The input can go from +10 to -10v, though I'm basically planning to use in the 3-4V range.
Thanks!
  #2
Old 08-04-2009, 05:15 AM
t_n_k t_n_k is offline
Default
Looks like you have a couple of issues (at least)
1. There are no ground references on your simulation schematic.
2. There is no series resistance for the LED.
3. You will probably need to use a split supply with center ground.
4. I don't think the LM741 is spec'd to run off a 9V supply.
Be advised - Several folk on this forum have a serious disliking for this op-amp.
  #3
Old 08-04-2009, 05:28 AM
Default
Thanks for the reply.
I meant the drawing to be a representation of the circuit that I actually prototyped on a breadboard and so the problem of current being drawn from the source is an actual one, not just one from simulation. Though yes, you're right -- I should put the ground in there else the simulation doesn't work.
I have tried connecting it up using a "virtual ground" by using 2 9V batteries and two 4.7KΩ resistors connected as such:
+ ----------------- +9V
9V \ 4.7
- /________virtual ground
9V / 4.7
- ----------------- -9V
with still the same problem that current is being drawn from the analog source.
I thought the LM741 was the "go to" workhorse amp? Id be willing to swap for something equally cheap and available.
  #4
Old 08-04-2009, 06:41 AM
Default
It would be useful if you draw the complete circuit as it is intended to function. Show all connections including the input and LED with ground points.
I'm not sure what your design concept entails with respect to driving the LED.
Are you hoping to see the LED brightness change as the analog output changes?
If the input to be buffered goes negative then you would need some steering diodes to still have the LED illuminated with negative inputs.
Keep in mind also that the LM741 will draw some quiescent current.
If you are using two 9V batteries then you don't need to create a virtual ground with the 4.7k resistors - the common connection point for the two 9V batteries can be the reference or ground. Did you follow what I said about needing a series (limiting) resistor for the LED?
  #5
Old 08-04-2009, 10:24 PM
Audioguru Audioguru is offline
Banned
Default
The input voltage of a 741 opamp does not work when it is near its negative supply voltage. The input of an LM358 works fine.
I could not remove all the Chicken Pox dots all over your schematic.
EDIT: Two ways to do it.
Do it like this:
Tags
Related Site Pages
Section Title
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Negative feedback opamp circuits
Worksheet Basic operational amplifiers
Textbook An analogy for divided feedback : Operational Amplifiers
Textbook Divided feedback : Operational Amplifiers
Textbook The "operational" amplifier : Operational Amplifiers
Video Lecture Basic Amplifier Configuration (Part 1) - Op Amps and Op Amp Circuits
Textbook Basic gate function : Digital Integrated Circuits
Textbook Integrator : Analog Integrated Circuits
Textbook Precision voltage follower : Analog Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oscillator, Voltage Divider, Help cheddy Homework Help 9 10-26-2007 12:21 AM
Electrostatics - Definition Of Capacitance Nirvana Physics 0 08-22-2006 10:49 AM
voltage vs. frequency ledjr Homework Help 3 11-26-2004 02:08 PM
Voltage came to zero, in circut after resister emraan General Electronics Chat 2 11-23-2004 11:58 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
