pls help me "IR 38khz transmitter"
ericyeoh
Joined Aug 2, 2009
58
Thx for reply
by the way the market at here dun hv 1738 only have 4838 and 4138
1st.question
if i use the component i mention above can it work?
2nd question
if i'm using 4838 and 4138 which IR LED should i use to match it?
pls do help me!
ericyeoh
Joined Aug 2, 2009
58
oh, ic great!
1 more question my frd, if my market here do not hv SFH405,
for the IR emitter, is that i need the characteristic of wave length = 950nm?
forward currect,forward voltage and the viewing angle no need to care right?
ericyeoh
Joined Aug 2, 2009
58
You are so good man!
i will construct my circuit once all the component has arrive and i will test it, if there are any errors occur i will ask for your help agian, thx dude!!
ericyeoh
Joined Aug 2, 2009
58
omg i need help agian
but by looking the circuit it say it's to be 38khz,
from the formula f =1.4/(R1 + 2R2) × C1
substitute all the value inside the frequency is about 34khz only what?
if i change the R2 = 18k , the frequency will close to 38khz!
can give opinion?
bertus
Joined Apr 5, 2008
22,944
I have found a simple calculator for the NE555 (one of the many):
http://www.g8ajn.tv/technical.htm
38 kHz will be at 18500 Ohms for R2.
Keep in mind that capacitors are not very accurate.
They can have tolerances upto 20 %.
When you want more stable signal use styroflex or siver-mica capacitors.
The use of metalfilm resistors will also help.
Greetings,
Bertus
jj_alukkas
Joined Jan 8, 2009
753
Try to use the minimum value possible for capacitors which have a greater tolerance. Or you could try resistors and capacitors suggested by Bertus.
Another way is to set up the circuit with the current components and measure the frequency on CRO. Then reverse claculate the constant (1.4) to adjust for the capacitor tolerance. After this do not change the capacitor and use the new constant for calculations. All this is not quite practical but good to know. !!
ericyeoh
Joined Aug 2, 2009
58
bertus
i just want to confirm,u mean the capacitors 0.001 micro should be use in styroflex or siver-mica type right?
Then the resisor metalfilm resistors -->18k or 20k or variable resistor?
bertus
Joined Apr 5, 2008
22,944
Yes, for the 0.001 μF capacitor you can take a styroflex or silver-mica.
Those will be more expensive than the ceramic.
You can take for the resistors 1K and 18 K metalfilm resistors.
You can place a potmeter of 5K in series with the 18K for adjustment.
Greetings,
Bertus
Audioguru
Joined Dec 20, 2007
11,248
This is the second recent thread that uses that very old circuit with its poor performance. Must be school homework.
The IR receiver doesn't work properly when it receives continuous 38kHz of IR. Then it reduces its gain. It expects to receive bursts of 38kHz IR pulses as shown in its datasheet.
The IR LED has rather low current pulses.
ericyeoh
Joined Aug 2, 2009
58
well the original 38khz circuit is done and test the distance can only acheive to 60cm. the receiver i using TSOP4138 and the IR emitter LED i just simply buy 2mm size.
The current through the LED is 65mA, wonder why the voltage through the LED only 0.7V.
The output of the 555 is rather low 2.1V only so the voltage across the 22ohm resistor is measure ~1.4V
But i replace another type of IR emitter, the distance can receive is defferent. but also cannot radiate more than 60cm
jpanhalt
Joined Jan 18, 2008
11,087
You need to modulate the emitter signal. See Figure 7 in the datasheet.
Some examples for such disturbance signals which
are suppressed by the TSOP41.. are:
• DC light (e.g. from tungsten bulb or sunlight)
• Continuous signal at 38kHz or at any other
frequency
When it receives a continuous 38KHz signal, it assumes that may be interference and decreases its sensitivity.
You can add the modulation with a second 555 or use a 556 for both the 38KHz and modulation.
Here is a schematic for something I made a few years ago to modulate the 38 KHz carrier.
John
Audioguru
Joined Dec 20, 2007
11,248
You cannot measure the 38khz voltage of the IR LED or of the 555 with a DC voltmeter or with an AC voltmeter. You must use an oscilloscope.
ericyeoh
Joined Aug 2, 2009
58
i;ve try to reflected the infrared signal by using a mirror to the TSOP receiver, by it failed..
Guys..Any opinion on how can i reflect the signal and the Receiver still can get the signal?
bertus
Joined Apr 5, 2008
22,944
It can be the glass in the mirro weakens the signal to much.
You will need a reflective plate without the glass in front.
In IR spectrometers the mirrors do not have glass, but are damped on a surface.
Greetings,
Bertus
