| Radio and Communications Discussion forum for all aspects of RF and communication engineering, including antennas, modulation regimes, RF circuits and filter design, and telematics. |
Thread Tools | Display Modes |
#1
Hello all,
![]() I want to know if somebody can help me on the following. -WHAT I HAVE: ![]() I have 5 XBee PRO modules version 1 with updated firmware with X-CTU software. -WHAT I WANT: ![]() I want to use 1 of them as master, and the rest connect directly to master. Master will send instructions as many times per second as it can to the 4 slaves and then, each one returns immediatly feedback. I want to use it at 115kbps, the distance is about 100 meters (300+ feet), in visual line (no obstacles). So... first, master (DL0) will send to first slave (DL1), then to second slave (DL2), and so on... so, -WHAT IS MY PROBLEM: ![]() My problem is that X-CTU recognizes them as XBP24 (not as XBP24-B)in which in the "Function Set" list doesn't list any item as "..Coordinator..." or "..Router...". I've seen lots of tutorials and in all of them they asume and have those coordinator and router functions sets. -SO MY QUESTIONS: ![]() Nice, does it work for this: Q1: does it mean that the microcontroller should change XBee's DL each time it changes slave?, can that be done?, Q2: if it can be done, it should be done with AT commands or with API.... sorry, i'm completely new at this. Ahother question: my available Function Sets are: -XBEE PRO 802.15.4 -XBEE PRO 802.15.4 NON-BEACON -XBEE PRO 802.15.4 DIGITAL IO ADAPTER -XBEE PRO 802.15.4 RS232 POWER HARVESTER -XBEE PRO 802.15.4 ANALOG IO ADAPTER ..version is 10CD THE question is: Q3: Which Function Set should i choose (from the above)? Q4: How will master know which slave is sending data? trully thanks for help , i've had this experiment freezed for about 1 year because of these lack of information.
#2
Quote:
Yes, i've been figuring that's the fastest solution up to now, and i'm implementing it in MPLAB/C18, using XBee as a replacement of a wire, without special XBee commands. However, I would prefer to take advantage of those special functions available in XBee's hardware/firmware, to make communication more efficient (more data per time unit (i.e. per second)), and i'm trying to find help on that issue, thank you very much. |
| Tags |
| multipoint, point, xbee |
Related Site Pages
| Section | Title | |||
| Textbook | Network protocols : Digital Communication | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| adc on xbee | liu123456 | Embedded Systems and Microcontrollers | 7 | 05-27-2009 03:03 PM |
| inexpensive timing relay circuit | strpdbas | The Projects Forum | 157 | 05-02-2009 02:39 PM |
| Kelvin Vs 4 point probe | Peter2 | The Projects Forum | 3 | 05-27-2008 10:01 AM |
| Kelvin Probe <-> 4 point Probe | Peter2 | Homework Help | 0 | 05-09-2008 10:45 AM |
| Microchip fixed point math library 16CXXX | atferrari | Programmer's Corner | 0 | 05-15-2005 12:55 AM |
| Thread Tools | |
| Display Modes | |
