All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-06-2006, 09:38 AM
mksa mksa is offline
Default
1) An unbalanced delta-connected load on a 400 V (line-line) 50 Hz system has
impedances of:
Za = 40 ohm; Zb = j 40 ohm; Zc = 20 j 20 ohm.
Calculate the phase and line currents.
2) A star-connected 400 V resistive load is connected to a 3-wire system. The
load has impedances of:
Za = 20 ohm; Zb = 40 ohm; Zc = 40 ohm.
Calculate the voltage of the neutral point.
3) An unbalanced star-connected load on a 220 V 60Hz 4-wire system. The legs of the load have impedances of:
Za = 5 ohm; Zb = 5 +j 5 ohm; Zc = 5 j 5ohm.
To insure correct phase voltage the star is connected to the neutral line
Calculate the phase and neutral currents.
4) An 400 V (line-line) star-connected unbalanced load has an earthed start point.
The load on phase 1 is 10 ohm, the load on phase 2 is 10 + j5 ohm and the load on
phase 3 is 10 j5 ohm. Calculate the phase currents and the star to earth current
and sketch the current phasor diagram.
I can do the balance system but the unbalanced I can't. and I would like to ask what is the diffrenece between xxx V (line-line) and xxxV xxHz and the difference between the 4-wire system and 3-wire system.
thank you.
  #2
Old 05-09-2006, 05:40 AM
Default
impedances of:
the phase currnts
for Iab=Vab/Za=400/40=10A
for Ibc =Vbc/Zb=400 phase-120/40 phase90 = 10 phase -210 A
for Ica=Vca/zc=400 phase 120 / 28.28 phase -45 = 14.144 phase 165 A
the line currents
for IAa = Iab-Ica=10 phase 0 - 14.144 phase 165 = 23.94 phase -8.79 A
for IBb = Ibc-Iab=10 phase -210 - 10 phase 0 = 218.43 phase -23.55 A
for ICc = Ica - Ibc = 14.144 phase 165 - 10 phase -210 = 191.793 phase 24.69 A
Vsn=Ya*Van+Yb*Vbn+Yc*Vcn/Ya+Yb+Yc
Vsn=1/20 * (400/ √ 3 phase 0) + 1/40 * 230.94 phase -120 + 1/40 * 230.94 phase 120 / (1/20 + 1/40 + 1/40) = 95.6751 phase 180.013 V
first we find Van , Vbn and Vcn which 220/ √ 3
Van=127 phase 0 V
Vbn= 127 phase -120 V
Vcn=127 phase 120 V
Ian = Van/Za = 127 phase 0 / 5 = 25.4 A
Ibn=Vbn/Zb = 127 phase -120 / 7.07 phase 45 = 17.96 phase 165 A
Icn=Vcn/Zc = 127 phase 120 / 7.07 phase -45 = 17.96 phase 165 A
In = Ian + Ibn + Icn = 25.4 phase 0 + 17.96 phase 165 + 17.96 phase 165
In = 13.15 phase 134.998 A
first we find Van , Vbn and Vcn which 400/ √ 3
Van=231 phase 0 V
Vbn= 231phase -120 V
Vcn=231phase 120 V
Ian = Van/Za = 231phase 0 / 10 = 23.1 A
Ibn=Vbn/Zb = 231phase -120 / 11.18 phase 26.565 = 20.66 phase 146.565 A
Icn=Vcn/Zc = 231 phase 120 / 11.18 phase -26.565 = 20.66 phase 146.565 A
In = Ian + Ibn + Icn = 23.1 phase 0 + 20.66 phase 146.565 A+ 20.66 phase 146.565 A
In = 25.45 phase 116.56 A
  #3
Old 05-09-2006, 05:41 AM
Default
impedances of:
the phase currnts
the line currents
Van=127 phase 0 V
Vcn=127 phase 120 V
Van=231 phase 0 V
Vcn=231phase 120 V
Tags
Related Site Pages
Section Title
Worksheet Delta and Wye 3-phase circuits
Worksheet AC network analysis
Textbook Three-phase Y and Delta configurations : Polyphase Ac Circuits
Textbook Harmonics in polyphase power systems : Polyphase Ac Circuits
Textbook Three-phase power systems : Polyphase Ac Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Power gain, output power and efficiency of an amplifier epsilonjon Homework Help 6 04-05-2012 08:13 PM
Need Help to solve these three phase balanced load questions Ryza Homework Help 10 06-12-2011 02:46 PM
delta star transformation yoamocuy Homework Help 4 11-03-2009 08:09 PM
calculation delta and star motor power? straw Homework Help 10 05-15-2007 03:47 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
