All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-17-2009, 05:44 PM
Metalfan1185's Avatar
Metalfan1185 Metalfan1185 is offline
Default Gel Cell Charging
ok, I have some Lead Gel cell batteries that are used in solar power systems. I have 4 at 12V and 7.0 Ahours a piece.
the part number is
Genesis
NP7-12FR
I am looking for a suitable circuit to charge them. It would be nice to charge them in pairs (24V) I know that EXIT signs use a charging circuit for a Gel cell battery but the amp hour rating is different since they use a smaller battery.
does anyone have a circuit that will allow me to charge these? via solar or by the grid?
__________________
"There is No Knowledge that is Not Power"
  #2
Old 07-17-2009, 08:30 PM
lightingman's Avatar
lightingman lightingman is offline
Default
Hello.
Jelly acid / Gell batteries are generaly charged with a constant voltage. This is usualy at around 13.8 volts for a 12 volt battery. There should be plenty of curcuits on the web.
And yes, you can charge these in series at 27.6 volts for two in series (24 volts).
The constant voltage supply should be capable of a few amps, as the batteries on recharge will pull a large current at first, falling of to around 50 to 100mA charged.
Hope this helps.
Daniel.
  #3
Old 07-17-2009, 09:08 PM
k7elp60 k7elp60 is online now
Default
Here is one that I built using a LM317T.
LM317T 12V Lead-acid charger
The AC/DC adapter in use is capable of 600mA @ 18V. (I used an Magnetek WDU18-600 adapter) Using parts on hand I chose to limit the charge current to about 450 mA. True the LM317T has built in current limiting, but it exceeds the rating of the AC/DC adapter. This adapter is a Class II transformer and has internal circuit protection, and using this internal protection without external current limiting could cause premature failure of it. For this reason I chose to use current limit in the LM317T circuit. The minimum input voltage for 450mA charging is very close to 17V.
LM317T circuit. R1 is selected to limit the current to a maximum amount and is determined by 0.7/ILimit. In the case of the shown circuit the current limit = 0.7V/1.5 ohms or 0.466A or 466 mA. To change the current limit value, just calculate the value of R1=0.7V/ILimit.
The charge voltage can be adjusted with no load on the charger. With a calibrated DVM connected + lead to point A and - lead connected to point B adjust the 2K potentiometer so the DVM reads 14.0 VDC. This sets the charger to the float or standby method of charging, or 13.7V.
The circuit boards are Radio Shack 276-159B, they come as one unit and can be snapped apart. Looking at the top of the board. The two larger red and black wires go the battery to be charged. The smaller red and black wires to the 2.1mm power jack. The various colored wire jumpers are the same type used on solderless breadboards. The color indicates their length in 0.1's of inches. For example yellow is 0.4" long. The long black one was made out of #22 solid black wire. I used a thermopad when fastening the LM317 to the heatsink, but regular heatsink grease could be used.
Charge Indicator
The charge indicator monitors the charge current and when this charge current decreases to the set level the LED is turned on. The colored wires are as follows: Red connected to point A, Yellow connected to point B, and Black connected to point C. All connections are to the charger schematic
IC1 is a voltage comparator that is using the reference voltage from the TL431AIZ precision regulator. The reference voltage is 2.5V @ 1%. This reference voltage is applied to the non inverting input (pin5). The sample voltage from the current limit resistor (R1) is amplified by U2, and is applied to the inverting input (pin 6). When this input voltage decreases to and is = too or less than the reference voltage, the comparator output goes high and turns on the LED thru the current limiting resistor connected to pin 7. This voltage amplifier U2 has a voltage gain = 1+20K/(R2 + R3).
The circuit as shown, when adjusted for a 7AH battery, the LED turns on when the charge current drops to
70mA. (7AH/100). With R1 of 1.5 ohms this voltage is 0.126V. From ohms law E=IR. So E=.070 x 1.5 =0.105V. The gain of U2 then has to be Vref/VR1 for the selected battery. Gain in this case=2.5/.105 =
23.81. To make this adjustment without a battery connected for a 7AH battery, connect a 200 ohm 2W resistor on the output terminals and adjust the 1K potentiometer on indicator board until the LED just comes on. For other size batteries calculate the charge current and value of resistor based on the charge voltage of 13.7 volts.
This circuit is also built on a Radio Shack 276-159B proto board. It also uses some of the preformed breadboard jumpers, the grey and white have been bent to connect some traces. The longer wires on the board are connected to the charger board.
The minimum input voltage for proper operation is 17.5 volts.
  #4
Old 07-17-2009, 09:51 PM
baysidebecca baysidebecca is offline
Default
Here's a good article about gel cells over at qsl.net;
http://www.qsl.net/wb3gck/gel-cell.htm
Also, National Semi has a design for a charger on page 10 of it's LM350 datasheet;
http://www.national.com/ds/LM/LM150.pdf
I found this charger worked better without the 500 ohm resistor across the input and output of the LM350. I also changed R1 to 2.7k in series with a 1k ohm pot, and R4 to 13k in series with a 5k pot to allow precise trimming of the charge and float voltage states.
  #5
Old 07-18-2009, 03:32 PM
Bernard's Avatar
Bernard Bernard is offline
Default
Talk is cheap, so here is some more: http://personal.atl.bellsouth.net/t/...ry_Charger.htm
SgtWookie suggests C/10,which I would follow. If the batteries were discharged in series so that they were in same state of charge, then " I " believe you could charge them in series; re-adjust some values and have at it. 12V batteries are already 6 cells in series.
Tags
Related Site Pages
Section Title
Worksheet Kirchhoff's Laws
Worksheet Batteries
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook JFET current regulator : Discrete Semiconductor Circuits
Textbook Current mirror : Discrete Semiconductor Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Practical considerations : Batteries And Power Systems
Textbook Battery construction : Batteries And Power Systems
Textbook Simple series circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ni-cd battery charging TADINADA VENKATESWARA RAO General Electronics Chat 1 03-28-2009 01:05 PM
MOBILE PHONE CHARGING b.shahvir General Electronics Chat 14 02-14-2009 04:42 AM
battery charging circuit rakesh696 Homework Help 0 01-02-2009 05:56 PM
CMOS read operation nearownkira Homework Help 4 05-15-2008 11:59 PM
The Basic Cell greenberet General Electronics Chat 3 11-22-2006 03:10 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
