All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 07-17-2009, 12:45 AM
Deano123 Deano123 is offline
Default Calculate number of turns in transformer
I need to find the required number of turns on the primary and the secondary windings of a transformer.
Given it is single phase 110/25KV railway TX on a 50Hz system
the max flux density is 1.5Tesla when 1.13pu volts applied.
assuming a core area of 0.3m2.
How would I find this?? number of turns prim and sec
  #2
Old 07-17-2009, 03:29 AM
t_n_k t_n_k is offline
Default
Hi Deano123,
I get the following
Erms=222.14xNxAxBmax
Did you mean the primary is 110kV?
If it's 110kV (RMS) then for conditions at 1.13pu Vprim = 124.3kV
So Np=123.4x10^3/(222.14x0.3x1.5)=1243 turns
That's a big core CSA! [0.55mx0.55m]
For the 25kV secondary
Ns = 281 turns.
These are very sparse specs for such a big unit. You haven't specified whether there a limitations on magnetizing current, losses, efficiency and a whole lot of other stuff. Do you intend to build this?
  #3
Old 07-17-2009, 03:33 AM
Default
Make that Ns=283 turns
  #4
Old 07-24-2009, 02:22 AM
kkazem kkazem is offline
Default Expert Answer
Hi Deano123,
Here is an answer from a top expert in the field, me! I have over 35+ years designing all kinds of transformers. I'm going to make it as simple as I can right now, as my time is very limited at the moment. This will require that you make a few conversions to use the CGS system, like 1.0 Tesla = 10,000 gauss.
Here is the formula for the first winding, based on the known input voltage. Normally the primary, so I'll use that term:
Np = number of primary turns.
Vp = known primary input voltage in volts. I'm assuming a sine wave input. If it's a square wave input, remove the factor of 1.11 from the denominator.
Bmax = maximum flux density in gauss.
Ac = effective core area in cm^2 (convert from m^2).
Fo = input frequency in Hz.
Np= (Vp X 10^8) / (4)*(1.11)*Fo*Ac*Bmax
In practice, you always round-up to the nearest integer turn. Then for the seconday turns, Ns = (Np*Vs)/Vp. This time, you can round up or down to the nearest integer turn, usually whichever is closest to the value you want.
In practice, the effective core area not only depends on the actual core area, but the type of core, like E-I laminations. Then it gets modified by the stacking factor; which depends on whether you interleave the laminations 1 by 1, 2 by 2, or butt-join them. It also depends on the lamination or tape-wound core tape thickness. The thinner the material, the closer to the actual measured core area.
That's probably more than you wanted to know. If you have more questions, please ask.
Good luck,
Kamran Kazem
  #5
Old 07-24-2009, 05:46 AM
bonjing bonjing is offline
Junior Member
Default
hi
what is the recommended frequency for 110v Ac and 220v ac
  #6
Old 07-24-2009, 07:27 AM
Default
Quote:
Originally Posted by bonjing View Post
hi
Whether you use my formula or kkazems you'll get exactly the same answer.
Something is seriously wrong with your specification if you really mean 110V primary.
With a CSA of 0.3 m^2 at 50 Hz you'll need just 1.243 turns for the primary - even rounding up to 2 turns gives a ludicrous result. I think you need to re-check your spec. The CSA of 0.3m^2 is probably not what you intend.
  #7
Old 07-24-2009, 08:19 AM
Junior Member
Default
others they specify the frequency, 60Hz for 120volts ac and 50Hz for 220volts ac...
what is the truth about this?
  #8
Old 07-24-2009, 08:26 AM
Default
There is a comprehensive listing here on wikipedia
http://en.wikipedia.org/wiki/Mains_power_systems
Tags
Related Site Pages
Section Title
Video Lecture Transformers (Part 1) - Inductors,Capacitors,Transformers
Video Lecture Transformers (Part 2) - Analysis of Transformer Circuits - Inductors,Capacitors,Transformers
Worksheet Power conversion circuits
Worksheet Basic AC-DC power supplies
Worksheet Advanced electromagnetism and electromagnetic induction
Worksheet Impedance matching with transformers
Worksheet Step-up, step-down, and isolation transformers
Worksheet Mixed-frequency signals
Worksheet Series-parallel combination AC circuits
Textbook Numbers and symbols : Numeration Systems
Similar Threads
Thread Thread Starter Forum Replies Last Post
Microwave transformer help?--hope this is the right place has91 General Electronics Chat 5 01-13-2009 08:17 AM
to calculate transformer windings ronald.dias Homework Help 2 08-19-2008 02:08 PM
Urgent answer needed about the number of windings of transformer muhsiul hassan Homework Help 6 08-18-2008 10:49 AM
relationship between core size and turns in transformer adeel General Electronics Chat 2 07-19-2008 05:04 PM
Transformer for Capacitor Discharge circuit Xray General Electronics Chat 4 05-19-2008 01:18 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
