Input signal control adjustment circuit
I am using a RoboteQ controller and I would like to make my input control circuit more robust without changing any of the feedback setting. The input is a joystick with a 5volt power source and the signal is set at 0-2.5 and 2.5-5. This works fine but I would like to reduce the input so there is some adjustability in the control.
In ideal solution would be a box or circuit that would de-amplify or amplify the input signal by adjusting a pot or flipping a switch.
Any suggestions would be very helpful.
See my project at www.designabilityinc.com
Thanks,
Wstuck
Thanks,
Wstuck
