What is an "HT" transformer?
ianderso
Joined Apr 26, 2006
While I've built many 9VDC solid-state projects (think effects for guitar players), I'm starting to test the waters on making some tube-driven devices. I was looking over some old schematics and kept seeing a reference to an "HT" attached to the plates of the tubes (usually ECC83s or similar) in the schems. I know it's a transformer reference, but what, exactly, does the "HT" mean?
Thanks,
IZA
Papabravo
Joined Feb 24, 2006
22,084
Thanks,
IZA
[post=16562]Quoted post[/post]​
I think it might mean "High Tension". This arcane terminology still shows up in high voltage circuits. It generally takes a step-up transformer to go from 120VAC to a typical +300VDC plate supply.
windoze killa
Joined Feb 23, 2006
605
[post=16564]Quoted post[/post]​
You are correct. HT means High Tension and EHT is Extra High Tension. EHT transformers are generally in the KV range.
HT transformers can have an O/P anywhere from about 100V to about 1KV. Some are multi tapped to provide voltages for the screen grid and supressor grid as well as the plate supply.
