All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Programmer's Corner
Notices
Programmer's Corner Discussion forum for all aspects of programming and software engineering. Any software programming language welcome: C, C++, C#, Fortran, Java, Matlab, etc.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 06-17-2009, 02:08 PM
ElectricalEngineer ElectricalEngineer is offline
Default Inputting a .wav file in MultiSim
Hey all,
Let me just explain to you the background of my situation. I am taking a Circuits 1 course and we are nearly done with the semester. We have a bonus assignment that requires us to create a passive filter(either High/Low/BandPass or BandReject) inorder to filter a distortion in an audio file in the form of .wav
The proffessor told us that this bonus assignment is beyond the scope of this course, and thus it will boost up our final grade upon completion.
I need someone to guide me in the right direction. She uploaded 2 files, noisyspeech.wav and cleanspeech.wav. After hours of trying to mess around with MultiSim, I have yet to reach a solution to that.
My gut feeling is that it will be a BandPass filter, hence I can use the Filter Wizard for creating that.
Here are the files:
Noisyspeech : http://www.tempfiles.net/download/20...isyspeech.html
Cleanspeech : http://www.tempfiles.net/download/20...eanspeech.html
After reading the chapter on Frequency Selective Circuits (Chapter 14, Electric Circuits, Nilsson & Riedel). I think that the filter I need to create is a Bandpass Filter since the human voice has a certain range of frequency, 85 to 155 Hz, hence I will need 2 cuttoff frequencies for the Bandpass filter inorder to filter out the noise in the speech file. I will be using the Filter Wizard, by selecting the Bandpass filter option.
My question remains as to how to input the .wav file on MultiSim
Thanks in advance, and please find the speech files attached.
  #2
Old 06-18-2009, 03:01 PM
davebee davebee is offline
Default
The proper way would be to read the header of the WAV file and decode the encoded sound format, playback rate, bits per sample, mono vs. stereo, and the start location and length of the data section.
But if you know the format of the WAVs, and it's a simple format, you can take shortcuts. The simplest WAV format are just bytes of digitized voltages. You read a byte, apply its value to a DAC, pause the delay specified by the digitization rate, and repeat to the end of the file. You can skip the first several dozen bytes of the file to jump over the header, then treat all remaining bytes of the file as data. This works in practice for playing WAVs, but I can't say how much your teacher will accept it for a school course. But on the other hand, the WAV header is not that difficult to decode.
In newer versions of Windows, you can right-click on the WAV file, get properties, and Windows will display many of the WAV file parameters. It seems like my computer network is blocking the file downloads so I can't get the actual files to see their format.
So I don't know Multisim, but reading data from the WAV file may reduce to as simple as inputting the file bytes, one by one, and treating them as samples of an audio soundwave.
Tags
Related Site Pages
Section Title
Textbook Resonant filters : Filters
Textbook Band-pass filters : Filters
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Inputting a .wav file on MultiSim ElectricalEngineer General Electronics Chat 4 06-17-2009 03:50 PM
MATLAB - Hiding a 24 bit file within an 8 bit file. ragzrangs Programmer's Corner 0 05-13-2009 01:09 PM
converting hex file to asm file nuttertools Embedded Systems and Microcontrollers 6 12-21-2008 08:07 AM
program for upsample & downsample .wav file sk4matlab Programmer's Corner 1 10-29-2008 10:36 PM
GUI project in mat lab m75allen Programmer's Corner 6 05-30-2007 11:51 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
