Cockcroft Walton Multiplier questions?
electronice123
Joined Oct 10, 2008
346
Can a CW multiplier be driven with a pulsed DC signal?
Is it possible to short out a CW multiplier's output without having a large voltage drop?
Can a CW multipler be used to charge a larger capacitor at a constant voltage?
beenthere
Joined Apr 20, 2004
15,819
1. No - gotta be AC
2. Voltage drop where? Shorting the output will certainly remove that voltage.
3. No. Charging proceeds at a constant rate, but only to some final voltage that can be controlled by the magnitude of the driving voltage.
