| Programmer's Corner Discussion forum for all aspects of programming and software engineering. Any software programming language welcome: C, C++, C#, Fortran, Java, Matlab, etc. |
Thread Tools | Display Modes |
#1
Dear guys,
I need some help programming VHDL. I need to break up a 8bit binary data to 2 4-bit data. Below is a glimpse of the code: library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use ieee.numeric_std.all; use work.CharLoopController.all; entity Sub_prog_test is Port ( en,reset,DisplayData,clk : in STD_LOGIC; Data: in STD_LOGIC_VECTOR (7 downto 0); ); end Sub_prog_test; architecture Behavioral of Sub_prog_test is begin process (clk,en,reset) variable upper_4bit, lower_4bit: std_logic_vector (3 downto 0); --------------------Some statement------------------------- ..................... upper_4bit<=Data(7)& Data(6)& Data(5)& Data(4); lower_4bit<=Data(3)& Data(2)& Data(1)& Data(0); However, when i do this, i get an error: "Wrong index type for Data." Please help Ridwan |
#2
Hi guys..
Realised my own mistake. Accidently named 2 variables similarly: 1 is data, other is Data. After changing Data to a new name: DataVar, everything went ok. Shucks.. I thought VHDL syntax was case sensitive. Best Regards Ridwan |
#3
i am a final year engineering student and i am seeking your help. I am required to design a Mesh Fabric Reference Design using VHDL programming. please refer to the following document. http://www.xilinx.com/support/docume...es/xapp698.pdf sample source code is not available for this and i have to design this from scratch. Would you be willing to help me. There will be good incentives. Please reply if interested. Thanks. |
#4
Oh man, this game is pretty sweet. Why can't more games have cutscenes that you want to see more of?
__________________ Conseil financement ********** travaux | Plan de financement credit immo | Calcul financement ********** |
| Tags |
| index, logic, std, vector, vhdl |
Related Site Pages
| Section | Title | |||
| Textbook | Parallel-in, parallel-out, universal shift register : Shift Registers | |||
| Textbook | Serial-in, parallel-out shift register : Shift Registers | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How To Scramble Numbers On These Tables? | hopestar | Off-Topic | 5 | 04-18-2009 04:40 AM |
| Saving a vector to a binary file | mentaaal | Programmer's Corner | 5 | 11-28-2008 09:45 PM |
| Treatise about Voltage | Ratch | Physics | 100 | 05-18-2008 07:55 AM |
| vector | braddy | Physics | 2 | 09-29-2006 01:07 AM |
| Thread Tools | |
| Display Modes | |
