All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-20-2009, 03:51 PM
trognholt trognholt is offline
Default applying 480 volts to a 440 volt transformer
I am in the process of hooking a used injection molding press and this machine was rated as a 220/440 volt machine. Our in plant power that I will be applying to thiis machine is 480 volts. That 480 volts is going to be applied to a transformer that is rated for 220/440 that drops the voltage to 100 volts for the controller power. My main questions are concerning the transformer and if this will cause the transformer to burn out and if I will still get the same 100 volt output or will this increase to due the higher applied voltage?
  #2
Old 05-20-2009, 04:21 PM
mik3's Avatar
mik3 mik3 is offline
Default
The output voltage of the transformer will be 240V instead of 220V.
It will not be a problem because transformers are designed to be able to handle voltages around their rated values due to variations in the line voltage.
Is the voltage stable enough or does it varies a lot?
  #3
Old 05-20-2009, 04:58 PM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Quote:
Originally Posted by trognholt View Post
Iand if I will still get the same 100 volt output or will this increase to due the higher applied voltage?
It will increase due to the higher voltage. At 480V in, the control voltage will be 109V. When the line surges to 500V (which is in keeping with specs for a 480V line) the control voltage will be at 113.6V. If your press controls can tolerate this, there is no issue. Maximum input voltage should be listed in the documentation for your press. If you don't have said documentation and cannot find it online, try contacting the press manufacturer.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #4
Old 05-20-2009, 05:11 PM
Slider2732 Slider2732 is offline
Junior Member
Default
Would be handy if there was an equivalent to logic circuits 7805 type voltage regulators.
78100 perhaps !
  #5
Old 05-20-2009, 07:44 PM
mik3's Avatar
Default
Quote:
78100 perhaps !
It is an AC voltage, it much complicated to regulate it with solid devices.
Power companies have taps on the transformers and change them according to the line load.
  #6
Old 05-21-2009, 12:51 AM
steinar96 steinar96 is offline
Default
Isnt there a risk of core saturation if the voltage per turn is exceeded. Unless the core is made with alot more turns then needed for safety.
  #7
Old 05-21-2009, 01:19 AM
mik3's Avatar
Default
Quote:
There is but I think transformers can tolerate voltages between 10% of their nominal value.
  #8
Old 05-22-2009, 05:54 AM
THE_RB's Avatar
THE_RB THE_RB is offline
Default
Transformers with light loads tend to overheat when the voltage is higher than spec due to the core losses. If your control circuit draws a relatively fixed current it is a typical industrial solution to put a series resistor to the power input to the transformer to drop the voltage 10% or so.
Tags
Related Site Pages
Section Title
Worksheet Negative feedback opamp circuits
Worksheet Advanced electromagnetism and electromagnetic induction
Worksheet Step-up, step-down, and isolation transformers
Similar Threads
Thread Thread Starter Forum Replies Last Post
480 volt single phase lighting Talmadge General Electronics Chat 2 12-21-2008 02:56 AM
6 Volt Power Supply from 12 volts (car battery) fuadramsey The Projects Forum 11 08-05-2008 10:31 AM
277 volt lighting / transformer Erin G. Off-Topic 6 03-14-2008 09:58 AM
capacitor discharge voltage help Sean Reed Homework Help 16 03-01-2008 05:19 AM
10.84 Volts to 1 volt or .90 volts Bcog General Electronics Chat 3 01-22-2008 03:21 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
