i'll try to give a brief description:
my circuit uses lots of discrete parts, and i wish to remove some where i can. after looking at my current board i think i can do w/o some caps on the supply side.
power is automotive power, comes into a muRata filter and then through a 7805 +5v regulator. within 1mm of the 7805 output is a 220uF electrolytic and a 1k pF ceramic for filtering, however, my current circuit uses more caps near each IC to help reduce EMF from automotive environment. within 1mm of each IC +Vcc i have a 1k pF ceramic and a 10k pF poly cap to reduce Vcc noise. and when i say "noise" i mean to guard against noise. i didnt actually see noise on the scope, etc.
1. is having the extra caps next to each IC really needed? or perhaps i only need the 1k pF ceramic? any suggestions?
2. my initial design failed to include a -V for the op-amps, so i plan to use a very simple circuit with a Intersil 7660 to get my -V. 7660 has a inernal oscillator and currently runs at 10kHz. should i also cap the -V near each IC to reduce noise? the 7660 +Vcc is fed from the 7805.
thanks in advance for any replies....
