I definitely don't know about either the topology or the capacitor of the psu. The psu is a ready to use product.In general power supply can provides over current for certain a transient.
By the way for short time most of the current will come from the output capacitor which is the one that need to withstand high current. Power supply topologies can also make the difference.
24V 11A power supply is definitely too much.
Probably a 3A power supply with the right capacitor will make the job.
The right capacitor depends also from the current transient.
The problem is that you should know how long the transient last and the output capacitor that is used within the power supply...
Which normally you don't know.
A soft start will solve definitely your problem.
Ciao,
Mauro
by Jake Hertz
by Duane Benson
by Duane Benson
by Aaron Carman
