All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-11-2009, 07:21 PM
dj_wizard dj_wizard is offline
Default Op Amp used as a function generator
Hey guys i need ur help i have this square and tri function gen.
i did this circuit and it worked i only need to know the application of the resistance in it .. and also i changed the op amps to the lm741
can anyone help plz ?
thnx in advance
here is the circuit
  #2
Old 05-11-2009, 07:28 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Check this thread out, see what you think...
http://forum.allaboutcircuits.com/sh...ad.php?t=12405
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
Old 05-11-2009, 07:33 PM
Default
but i didn t use the pulse generator 555 ... now i know the 2nd op amp works as an integrator to the 1st o/p which is a square function .. but how does the first one works ?
  #4
Old 05-11-2009, 07:41 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
Take a look at this page of the eBook:
http://www.allaboutcircuits.com/vol_3/chpt_8/12.html
It is about positive feedback used with an opamp.
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #5
Old 05-11-2009, 07:47 PM
Default
thnx mate it was very helpful .. thnx both of u
  #6
Old 05-11-2009, 11:13 PM
Audioguru Audioguru is offline
Banned
Default
The performance of a lousy old 741 opamp is bad above only 9kHz. Many better opamps cost the same, are single, dual and quad and perform well up to 100kHz.
  #7
Old 05-12-2009, 01:48 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Quote:
Perhaps you could prepare an update of National Semiconductor's Op Amp Circuits Collection (including the function generator of this topic, on page 9) using the modern chips. Then all the folk looking for circuits would no longer be offending you by using older style chips.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #8
Old 05-12-2009, 02:41 AM
Banned
Default
The lousy old 741 opamp should have been buried 20 years ago.
The very old LM107 opamp in the original circuit performs poorly above only 5kHz and was buried years ago.
  #9
Old 05-12-2009, 02:57 AM
Super Moderator
Default
So how about writing that upgrade? You could reduce the number of people learning on old chips! You could personally bury the old chips (metaphorically speaking).
Or you could post a circuit here with a more modern chip.
Or I suppose you could just keep whining.
__________________
- Michael Faraday
  #10
Old 05-12-2009, 05:33 AM
bertus's Avatar
Administrator
Default
Here is almost the same schematic from the datasheet of the TLC272, a cmos opamp.
Greetings,
Bertus
__________________
Tags
Related Site Pages
Section Title
Worksheet Nonlinear opamp circuits
Worksheet Linear computational circuitry
Worksheet Positive feedback opamp circuits
Worksheet Negative feedback opamp circuits
Worksheet Basic operational amplifiers
Textbook Operational amplifier models : Operational Amplifiers
Textbook Practical considerations : Operational Amplifiers
Textbook Voltage-to-current signal conversion : Operational Amplifiers
Textbook Class B audio amplifier : Analog Integrated Circuits
Textbook Voltage comparator : Analog Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Function Generator marims Embedded Systems and Microcontrollers 7 05-14-2009 06:20 PM
Cheap and simple RF amp for signal generator Ziplock9000 Radio and Communications 2 04-15-2009 09:08 AM
Adjusting a broken function generator afaik General Electronics Chat 2 12-22-2008 07:50 AM
Help In Function Generator bilalsaeed General Electronics Chat 9 09-20-2008 12:50 AM
xr2206 function generator poindexter The Projects Forum 7 05-12-2007 05:23 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
