All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-07-2009, 01:35 AM
z-man z-man is offline
Default Voltage meter using LM3914
Hello! I am trying to replace an analog meter with a newer LED version in an amplifier, but am having problems with the input. What I want to do is display a max physical voltage of 0.28V (the max needle deflection of my analog meter) when I have my 30 LED's lit. I tried to find some sort of doubler/quadrupler circuit on the web to increase my voltage, but can't seem to figure out how to satisfy the input for the chip(s). Can this even be done? I was hoping not to modify any existing circuits in the amp. Any help will be appreciated.
  #2
Old 05-07-2009, 01:59 AM
Audioguru Audioguru is offline
Banned
Default
An LM3914 has a full scale sensitivity of 1.25V. For a sensitivity of 0.28V you must amplify the input voltage from 0.28V to 1.25V which is a gain of 4.46.
An opamp can be used as the amplifier.
The LM3914 is a linear voltmeter. An LM3915 is a logarithmic meter for audio levels and light brightness.
  #3
Old 05-10-2009, 12:02 AM
Default
Thanks Audioguru, I guess I was just overlooking them for some reason. I decided on the LM6132 because of the low operating voltage, but was wondering if you might suggest something else?
Tags
Related Site Pages
Section Title
Worksheet Precise diode circuits
Worksheet Linear computational circuitry
Worksheet Peak, average, and RMS measurements
Worksheet Voltmeter design
Worksheet Performance-based assessments for basic electricity competencies
Textbook Voltage comparator : Analog Integrated Circuits
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Make your own multimeter : Dc Circuits
Textbook Voltmeter usage : Basic Concepts And Test Equipment
Textbook Multimeters : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
High Voltage and High Current Load Switch/Relay virtualeast The Projects Forum 3 01-11-2010 08:23 PM
LM3914 Driving Dual color LED's on single polarity supply Metalfan1185 General Electronics Chat 9 10-02-2008 02:18 PM
voltage dividers pilotnmech Homework Help 16 01-14-2008 02:30 PM
Analog to digital conversion Pat51 The Projects Forum 7 01-22-2007 01:54 AM
Using my new multi meter and a voltage test meestahelectro The Projects Forum 2 08-14-2006 12:37 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
