All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 05-06-2009, 05:57 PM
adam_246 adam_246 is offline
Default R-C coupled amplifier (feedback)
Hi all,
I am new on here and seeking some help please.
I am struggling to answer the following revision question.
An RC coupled amplifier has a feedback network added to modify its performance. Before the addition of the network, the amplifiers gain was 25<180(degrees).
3% of the output voltage is fed back to the input via the feedback network, which introduces a phase shift of 60(degrees) at the midband frequency of the amplifier. Determine the following:
1) the value of the feedback factor in polar form
2) the loop gain, in polar form
3) the closed loop gain in polar form
4) the gain and phase margins of the feedback amplifier.
Thanks in advance
  #2
Old 05-06-2009, 09:53 PM
Default
This is what i have got so far:
B= 3% = 3/100 = 0.03
LOOP Gain
AV= 25 < 180
BAV= 0.03 x 25 / ( 180 + 60)
= 0.75/<240
BAV IN PF = 0.75 < -120 DEG
1 - BAV = 1 - ( 0.375 - j0.65) (J FORM FROM ABOVE)
= 1.375 = 0.65
Polar = 1.52 < 25 DEG
If anyone could guide me it would be much appriciated
  #3
Old 05-07-2009, 11:21 AM
t_n_k t_n_k is offline
Default
Is that positive or negative feedback? i.e. Is the feedback added to the input signal or subtracted from it?
  #4
Old 05-07-2009, 04:51 PM
Default
Quote:
It is negative feedback.
  #5
Old 05-08-2009, 01:18 AM
Default
Hope the attachment makes sense.
  #6
Old 05-08-2009, 04:42 PM
Default
I see how you have worked out the loop gain and closed loop gain.
How can i work out the gain and phase margains?
Also the feedback factor?
  #7
Old 05-08-2009, 10:08 PM
Default
I would use the term I denoted as 'H' for the feedback factor.
Others may disagree and hopefully you will receive other comments & views, but I don't believe there is sufficient information to work out the gain and phase margins. Primarily because the feedback definition is quite vague - we are just told it has a mid-band gain and phase. Nothing about it's cut-off frequencies and / or roll off behavior. Then we have the amplifier described as an RC coupled type - without any elaboration other than the gain & phase [presumably mid-band]. To derive gain and phase margins one usually graphs the open loop frequency [gain vs phase] response and "reads off" the margins as elaborated by said plots.
I think it's quite possible for the example's resulting closed loop system to be unstable anyway - and under those circumstance the concepts of gain and phase margin are rather hazy, to say the least.
  #8
Old 05-09-2009, 02:51 PM
Default
Thanks for all your help.
Does anyone else have any opinions on this?
Tags
Related Site Pages
Section Title
Textbook More on AC "polarity" : Complex Numbers
Worksheet Inverting and noninverting opamp voltage amplifier circuits
Worksheet Oscillator circuits
Worksheet Multi-stage transistor amplifiers
Worksheet Class A BJT amplifiers
Textbook Harmonics in polyphase power systems : Polyphase Ac Circuits
Textbook Feedback : Bipolar Junction Transistors
Textbook Input and output coupling : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Textbook Simple vector addition : Complex Numbers
Similar Threads
Thread Thread Starter Forum Replies Last Post
DC coupled multistage amplifier questions UTEEstudent The Projects Forum 7 03-13-2009 03:02 AM
amplifier feedback factor anita bosher Homework Help 4 11-13-2008 09:08 AM
Amplifier feedback Unregistered Feedback and Suggestions 1 03-29-2008 01:13 PM
voltage gain for a two-stage feedback amplifier... xp_even Homework Help 3 10-20-2007 09:57 AM
voltage feedback operational amplifier with rail-to-rail output gigilala General Electronics Chat 4 10-01-2006 12:42 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
