I need a "normally-open, timed-closed (NOTC)" relay, as described in vol_4, chpt_5, pg 3. I did find one circuit (linked below) I think would work, but I'm not sure if it works how I want. Can someone explain how the circuit below works in layman's terms?? Is it as simple as using the "+12 Volts" wire as the input trigger?
http://ourworld.compuserve.com/homepages/Bill_Bowden/page2.htm#delay.gif
The function I need is to delay a CONSTANT alarm input for a few seconds, and reset/kill the circuit when the input signal is removed. My goal is to fit 3 sirens (1 weak, 1 very loud, 1 interior "pain generator") on my car's alarm, but to keep it quiet when I arm/disarm/false trigger the alarm. Everything else I found were references to time-delay circuits that use a PULSED trigger/input (555 timer), or very complicated circuits that do not denote pulsed or constant input.
PS: Designing such a circuit for me is out of my league atm. That would be like asking most of you rebuilding an engine or designing/fabricating an entire turbocharger kit from scratch (which I've done).
