All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-27-2009, 11:06 PM
frenchie29 frenchie29 is offline
Default Stereo to Mono connector wiring
I need to go from a stereo 3.5 male cable to a stereo 3.5 female connector The thing is the amp I am working on is mono. On the PCB I have Audio In and Ground. How do I wire the female connector to the PCB??
I know with XLR pin 1 & 3 are looped together is it the same for TRS????
  #2
Old 04-27-2009, 11:43 PM
Audioguru Audioguru is offline
Banned
Default
You do not know if the music source will blow up if you short the channels together. I would make a mixer with two series 3.3k resistors.
  #3
Old 04-28-2009, 12:25 AM
Default
Quote:
What do you mean by mixer? Basically it would be the same as one of those connectors that goes from stereo to mono.
  #4
Old 04-28-2009, 12:44 AM
Default
That's what I did for now, I know I'm doubling the impedance but that's all I can think of.
connector---------------PCB
tip-------------------->Audio In
Ring------------------->Audio In
Sleeve----------------->Ground
  #5
Old 04-28-2009, 01:38 AM
Default
http://www.mediacollege.com/audio/co...jack-mono.html
If I go with this it's
Tip to Audio in
Ring to Ground
Sleeve to Ground
  #6
Old 04-28-2009, 10:25 AM
tkng211 tkng211 is offline
Member
Send a message via MSN to tkng211 Send a message via Skype™ to tkng211
Default
You may try this by adding a few parts. Then you can have the signals from both left and right channels feeding to the mono amplifier.
  #7
Old 04-28-2009, 01:57 PM
Default
Very nice, are the resistors necessary? I did it without resistors I taught it would double up the signal level but it didn't. Would jumping the L and R and put 1 10k do the same thing? Also did you make that schematic? The software I use doesn't have any audio symbols at all.
  #8
Old 04-28-2009, 08:15 PM
Banned
Default
The resistors are the mixer. They mix the left channel with the right channel to avoid shorting the left channel to the right channel that might blow up something.
An XLR connector is a mono balanced signal, not stereo. By shorting one of the balanced wires to ground then the signal becomes unbalanced.
  #9
Old 04-28-2009, 08:57 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
I agree the simplest and safest method is with just a pair of isolation resistors. (These aren't really in series, except from the point of view of the source ends...they're in parallel "looking" the other way.
eric
__________________
REAL men don't need voltmeters.
  #10
Old 04-28-2009, 11:27 PM
Default
What about those stereo to mono connectors they sell at Radio Shack? I think they just mix the 2 signals together. I'll try the resistors tonight. Thanks guys
Tags
Related Site Pages
Section Title
Worksheet Basic troubleshooting strategies
Worksheet Electrical connections
Textbook Networks and busses : Digital Communication
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Waveform analysis : Ac Circuits
Textbook PC Oscilloscope : Ac Circuits
Textbook Musical keyboard as a signal generator : Ac Circuits
Textbook Sensitive audio detector : Ac Circuits
Textbook Sensitive voltage detector : Dc Circuits
Textbook Setting up a home lab : Introduction
Similar Threads
Thread Thread Starter Forum Replies Last Post
Switch between stereo channel selector and audio amplifier Yarrow The Projects Forum 8 01-04-2010 04:15 AM
Kenwood stereo Power amplifier KAC-5020 Dingoden General Electronics Chat 4 12-11-2008 01:07 AM
Need help identifying a part on a Pioneer stereo highplainsdrifter General Electronics Chat 1 08-28-2008 01:02 AM
Format of a stereo station mik3ca Radio and Communications 2 02-25-2008 06:22 PM
Stereo Power Freyosa General Electronics Chat 11 01-24-2006 09:50 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
