All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-26-2009, 05:43 PM
onlyvinod56's Avatar
onlyvinod56 onlyvinod56 is offline
Smile CD4046 & NE566
iam working with a project based on VCO.
What is the range of contrl voltage that can be given to
i) pin 9 of CD4046
ii) pin 5 of NE566.
required frequency range is [33KHz 336KHz]
Thanq
  #2
Old 04-26-2009, 06:26 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
Do you have the datasheets?
It should be possible with both.
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 04-27-2009, 12:12 PM
Default
Hello bertus,
i have seen the datasheets. But i didnt understand this modulating voltage.
anyways, Today morning i worked with CD4046.
Iam attaching the schematic here.
By varying the 50k pot, i got almost the correct result. the maximum frequency i got with this circuit is 333.33KHz. & minimum something around 10Khz.
Next i removed the 50K pot. and i connected an external variable power supply to the pin 9 w.r.t ground. i started varying the voltage from 0v.
As iam increasing the voltage 0, 0.1, 0.2,.... exactly at 0.3v iam not getting any thing except two horizontal lines in oscilloscope.
what shud i do. I dont need pot. I have to control with external voltage.
thanQ
  #4
Old 04-27-2009, 05:25 PM
bertus's Avatar
Super Moderator
Default
Take a look at this thread: http://forum.allaboutcircuits.com/sh...ad.php?t=18409
In there you will find this picture for calculating the resistors and capacitor
Greetings,
Bertus
__________________
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
PLL IC CD4046 help needed kahafeez The Projects Forum 26 01-25-2009 07:18 PM
FSK modulator using CD4046 plz help! Sheryl The Projects Forum 4 06-14-2008 06:48 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
