All About Circuits Forum
Go Back   All About Circuits Forum > Abstract Forums > Math
Notices
Math Discussion forum for anything math related.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 04-11-2009, 04:26 PM
Panterulez Panterulez is offline
Default Time scaling and Time shifting in a signal
For a given signal X(t), why is it that if I were to do a time scaling and shifting such that Y(t) = -2x [(t-2)/2], the order at which operation is done first matters ?
For example if I were to do the time scaling first before the time shifting, then X(t) will be expanded time scale wise by 2 after which there will be time shift of two units to the right. But if I were to reverse the order by doing the time shifting first, then this time round, X(t) will be shifted to the right by one unit to the right before the time scale is expanded by 2. Why is this so mathematically ?
  #2
Old 04-11-2009, 04:34 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
This happens with non-linear operations. They are not commutative in the same way that matrices are not commutative.
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 05-03-2009, 09:04 AM
whzahp whzahp is offline
Default Solution
The give signal can be written as : y(t) = -2 * x(0.5t -1)
So there are 3 things to be done, Amplitude scaling, time scaling & time shifting.
If time scaling is done first, then the sequence of events are as follows :
1. Time scaled version of x(t) = a(t) = x(0.5t)
2. Time shifted version of a(t) = b(t) = a(t-1) = x( 0.5(t-1) ) = x(0.5t -0.5)
3. Finally doing amplitude scaling will result in y(t) = -2*x(0.5t - 0.5)
which is clearly not the signal which we require
If time shifting is done first, then the sequence of events are as follows :
1. Time shifted version of x(t) = a(t) = x(t - 1)
2. Time scaled version of a(t) = b(t) = a(0.5t)
{which means replace t by 0.5t in the fn a(t) }
Therfore b(t) = a(0.5t) = x(0.5t -1)
3. Finally doing amplitude scaling will result in y(t) = -2*x(0.5t - 1)
which is the signal which we require
Moral : Do time shifting first before u do time scaling
  #4
Old 01-03-2010, 05:21 AM
trailblazer trailblazer is offline
Default
Is x(-2t+5) advanced with respect to x(-2t) or delayed
  #5
Old 01-11-2010, 04:57 AM
scythe's Avatar
scythe scythe is offline
Junior Member
Default
You can figure this one out just by coming up with a simple example! It would be advanced, because you are referencing a future part of the signal for the current time.
Tags
Related Site Pages
Section Title
Worksheet Calculus for electric circuits
Worksheet Basic algebra and graphing for electric circuits
Worksheet High-reliability circuits
Worksheet Shift registers
Worksheet Multi-stage transistor amplifiers
Worksheet Mixed-frequency signals
Worksheet Time constant calculations
Textbook Parallel-in, parallel-out, universal shift register : Shift Registers
Textbook Serial-in, parallel-out shift register : Shift Registers
Textbook Introduction : Shift Registers
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
