All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-03-2006, 06:57 PM
R.Stephen R.Stephen is offline
Default
[attachmentid=1223]
Electronic design assistance needed.
I am seeking assistance from someone that would assist me in designing a custom circuit for a prototype that I am working on. I would be willing to work out a mutually lucrative contract with someone who wanted to get involved with this project. I will however require a confidentiality contract to be signed along with a specific contract, outlining both of our responsibilities and obligations. If this sounds interesting to you please contact me. Below is a “general” description of the circuit and the design objectives.
General Circuit description: SEE ATTACHED!
Circuit components: 1. Tank filled with liquid
a. fluid hose to pump
b. (FAULT) switch or Low level float consisting of a magnetic float incased around a tube with a no/nc reed switch.
2. Liquid 12vdc @ 5a pump
3. Trigger momentary switch to activate cycle.
4. Reset Switch.
Circuit requirements
When momentary switch(3) closes for 2 seconds, pump(2) will activate (ON) for an adjustable time from 2-3 seconds. After pump(2) has activated an adjustable timed 10-60 minute countdown of the pump (off) will begin. Any additional signals from momentary switch(3)will not interrupt this cycle. If when cycle is complete a switch closure from momentary switch(3) still exists the cycle will repeat. If at any time circuit receives a signal (NC/NO) from fault switch(1-B) cycle will be immediately shut down and not restart until manual reset switch(4) is pressed.
Notes: 3. Momentary switch to activate cycle could be in the form at current of an ultrasonic movement detector as seen here.
http://info.hobbyengineering.com/specs/DIY...t%20switch'
I have not tested this switch yet to insure that it will perform the necessary detection capabilities, so this may change if a more suitable device is located.
Notes:4 The reason for the manual reset button or circuit is that the float switch is very sensitive. The potential exists that when liquid level is low and pump activates, the amount of fluid that the pump draws to prime itself, may momentarily fool the float switch into thinking that tank has become empty. When pump shuts down and pump looses it’s prime a small amount of fluid will back flow from pump back into tank causing the level to fool the fault switch into thinking it has an acceptable level. I want to avoid a toggling effect that may be created when level gets into this level of liquid.
General Notes: I have found several cyclic timers that could possibly perform the above list of requirements. They are listed here.
http://www.hobbytron.com/UK191.html
or
http://www.electronickits.com/kit/co...lec/ck1614.htm
Either of these circuits could work, with slight modifications, but they are not exactly what I am looking for.
R. Stephen
03/03/06
  #2
Old 03-03-2006, 11:15 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
Quote:
Originally posted by R.Stephen@Mar 3 2006, 03:57 PM
[attachmentid=1223]
4. Reset Switch.
or
R. Stephen
03/03/06
For a quick prototype, have you considered using a Programmable Logic Controller (PLC) from Allen-Bradley or similar vendors. They are readily available, easy to program, and widely supported. This application would be up and running long before you could design and fabricate or breadboard a custom design. Another advantage would be that if your requirements changed or you desired some new feature it could be added quickly and painlessly.
Once you have a PLC design working the way you wanted, you could design a custom product to mimic the PLC solution.
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 03-05-2006, 03:24 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
A couple of monostable multivibrators and some AND gates might do the trick. One MMV for the two-second window, one for the pump on-time, another for the 10-60 minute lockout.
Another monostable and logic gate could eliminate the need for a reset switch - the "liquid level low" condition could be initiated only if the float switch remains tripped for ten or twelve seconds.
[attachmentid=1229]
This project reminds me of the self-administered morphine gizmo that my wife had when she was in the hospital. A hand-held switch triggered injection of morphine into her IV, but only one carefully measured dose in a specified time interval. She could press the button any time the pain got out of hand, but the machine would not let her overdose. I suspect the button had a bit of a "placebo effect" as well.
I am curios... what does "mutually lucrative" mean?
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #4
Old 12-05-2006, 12:29 AM
Starwalker9 Starwalker9 is offline
Default
If you are still looking for someone I would be glad to get involved. I am currently designing circuits for television and music video special effects. I also design and manufacture circuits for the traffic and amusement industries. Dont be intimidated into thinking I charge top dollar! Just a regular guy who is always looking for work. Your controls could be handled easily with a $5 microcontroller. Email me if you are interested. I write firmware, design PCBs and manufacture if required.
starwalker9@yahoo.com
  #5
Old 12-05-2006, 08:01 AM
Gadget Gadget is offline
Send a message via MSN to Gadget
Default
EZ PeeZee.
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for digital circuit competencies
Worksheet Latch circuits
Worksheet Electromechanical relay logic
Textbook Switch types : Switches
Worksheet Thyristor application circuits
Worksheet Oscillator circuits
Worksheet Bipolar junction transistors as switches
Worksheet AC motor control circuits
Worksheet Switches
Textbook pH measurement : Electrical Instrumentation Signals
Similar Threads
Thread Thread Starter Forum Replies Last Post
Electronic Circuit Design ( Score Chart) KharilManan The Projects Forum 0 03-23-2012 07:22 AM
Circuit Explanation Needed. sonic007 General Electronics Chat 19 03-08-2012 05:21 PM
Time Delay Circuit with Delay-On and then Delay-Off louie55 The Projects Forum 15 02-03-2012 12:41 PM
Simple Circuit Problem(4.5v circuit) help needed for motor and led circuit kissdom General Electronics Chat 19 01-14-2012 04:42 PM
Circuit Design Help - Timer for Automotive J.Green The Projects Forum 1 07-16-2008 06:00 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
