This project is simpler than the "Quattuor" project. It doesn't use the LM1036 chip as audio control: it uses a simple volume control instead. As "Quattuor", it uses a pair of Visaton FR 10 4 OHM drivers. Unfortunately, those drivers are not magnetically shielded, so cautions must be taken when using them near a CRT monitor, TV or any other device containing a CRT.
The amplifier is able to deliver about 4W each channel, and has a gain per channel of 22.39dB (13.17V/V). The predicted frequency response is 60-20000Hz (-10dB).
List of components:
C1 4.7mF electrolytic capacitor (25V);
C2/4 100µF electrolytic capacitor (25V);
C3/5/10/15 100nF polyester capacitor (63V);
C6/11 2.2µF electrolytic capacitor (6.3V);
C7/12 33nF polyester capacitor (63V);
C8/13 470µF electrolytic capacitor (25V);
C9/14 1mF electrolytic capacitor (25V);
D1 1N5400 rectifier diode;
D2 - Red LED (GaAsP/GaP)
FTE1/2 Full-range speaker Visaton FR 10 4 OHM;
HS1/2 - 10ºC/W passive heatsink (for TO-220);
IC1/2 TDA2003 audio power amplifier (with 10ºC/W heatsink);
J1 - 5.5mm x 2.1mm DC socket;
J2 - 3.5mm TRS socket (stereo phone socket);
J3/4- RCA socket;
JW - 26AWG stranded wire;
R1 680Ohm carbon resistor (5% tol., 1/2W);
R2 4.7K double gang potenciometer (10% tol., 1/8W);
R3/9 1.8K carbon resistor (5% tol., 1/8W);
R4/10 270Ohm carbon resistor (5% tol., 1/8W);
R5/11 47Ohm carbon resistor (5% tol., 1W);
R6/12 220Ohm carbon resistor (5% tol., 1W);
R7/13 2.2Ohm carbon resistor (5% tol., 1/8W);
R15/21 1Ohm carbon resistor (5% tol., 1/8W);
S SPST switch.
Electrical parameters:
- Vd min = 8.80V
- Vd max = 15.72V
- Id (Vd = 13.5V) = 842.5mA
- P (Vd = 13.5V) = 11,37W
Amplification characteristics (each channel):
- Input impedance: 1.437-4.7KOhm
- Gain: 22.391dB (13.17V/V)
- Output power (Z FTE = 4Ohm): 4.7W
Audio characteristics:
- Frequency response: 60-20000Hz
- Sound pressure (SPL): 92.70dB (each channel)
Recommended enclosure specifications:
- Type: Ported (4th order Chebychev alignment)
- Volume: 6,319L
- Recommended duct: Monacor BR-30HP (length: 56mm)
- Resonant frequency (Fb): 68.494Hz (-10dB)
- -3dB frequency (F3): 59.984hz
Translations:
- Alimentação 13,5V CC - 13.5VDC supply;
- Canal direito - Right channel;
- Canal esquerdo - Left channel;
- Entrada de áudio estéreo - Stereo audio input;
- EDM - Short for left, right, ground (LRG);
- Positivo - Positive (V+);
- Secção - Section;
- Secções - Sections.
Important: When printing the PCB and the panel prints, print them in real size. This is a requirement, even if you print in A4. Some printers will reduce to fit. This procedure should work for both A4 and Ansi A (8.5" x 11") formats. The PCB should measure 120mm x 83mm.
List of components:
J3/4- RCA socket;
S SPST switch.
- Vd min = 8.80V
- Vd max = 15.72V
- Volume: 6,319L
Translations:
- Secção - Section;
