All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-31-2009, 03:47 PM
Management Management is offline
Default I-V Characteristics (Curve Trace) - FET
Hi, does anyone know how I can get a I-V characteristic of a FET in PSpice? Basically the same thing a curve trace would give you.
If that isn't possible, how can one confirm some of the specs on a datasheet.
Basically I would like to test how a particular model is operating. What specs should I be focusing in, Vth, Idss, Drain Source Voltage and Current, Vgs voltage characteristics, etc?
Thanks in advance.
  #2
Old 03-31-2009, 06:40 PM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
Thanks in advance.
I can show you how to do it in LTspice. You could probably easily translate that into Pspice. Let me know if you want to see it.
  #3
Old 03-31-2009, 07:56 PM
Default
Quote:
Yes please show me. I also have LTspice installed but I think I would be able to translate it because I am more comfortable with Pspice than LTspice. Either way should work for me though.
Thank you so much.
  #4
Old 03-31-2009, 08:42 PM
Ron H's Avatar
E-book Developer
Default
It's just nested DC sweeps of Vds and Vgs. If you save the .asc file in the location where your other LTspice sims are located, you can then start LTspice and run this sim. Right-click on the .dc directive to see the source sweep parameters.
If you don't have a model for 2N4416, pick another model.
File Type: asc curve tracer jfet.asc (571 Bytes, 149 views)
The Following User Says Thank You to Ron H For This Useful Post:
SiegeX1 (05-13-2011)
  #5
Old 04-01-2009, 11:01 AM
Default
Your the best. Thank you very much.
Also, is it possible to do a CV curve in PSpice or LTspice? Would I just do a DC Analysis and sweep the gate while shorting the drain and source to groung? If so, how would I plot the high frequency curve and low frequency curve?
Thanks again.
  #6
Old 04-01-2009, 05:39 PM
Ron H's Avatar
E-book Developer
Default
Thanks again.
I used to run CV sims on MOSFETs when I worked at Micron. The principle is fairly simple:
I=C*dv/dt
C=I/(dv/dt)
For a reverse-biased junction, or a MOSFET gate, apply a ramp (dv/dt) to the gate. You have to be judicious about the choice of dv/dt. First, choose a slope like 1e6 v/sec, or 1e3 v/sec, so that the capacitance is in uF or mF.
If you choose 1e12, and the capacitance is a few pF, you will get a few amps of current, which will cause series resistance in the model to be significant, screwing up your results.
If you choose a slope that is too slow, like 1 v/sec, the current will be so low that leakage current will be significant.
You can see Miller capacitance with this technique, as in the attached simulation. I added known values of R and C as a sanity check.
Obviously, you can change Vds or Rd, depending on what you want to measure. You will have to change the amplitude of the gate ramp to accommodate devices with different Vgs(th).
Tags
Related Site Pages
Section Title
Worksheet Junction field-effect transistors
Textbook Depletion-type IGFETs : Insulated-gate Field-effect Transistors
Textbook Active-mode operation : Junction Field-effect Transistors
Textbook Active mode operation : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Using FET as a switch to bypass a resistor? redbird_is The Projects Forum 5 03-06-2009 11:17 PM
How to measure I-V family with a curve tracer or o-scope globtrotah The Projects Forum 4 05-15-2008 05:30 AM
voltage-to-current converter chip for oscilloscope XY mode for curve tracing? relicmarks General Electronics Chat 7 04-07-2008 03:32 PM
JFET/MOSFET Characteristics seracht Homework Help 1 11-13-2007 12:17 AM
Drive an fet with a 555 and a different power source/not the same one that powers fet arthur92710 General Electronics Chat 108 11-08-2007 07:51 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
