All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-31-2009, 11:16 AM
Kyuman's Avatar
Kyuman Kyuman is offline
Default How to explain? Resistors and Capacitors
The tolerances in Resistors and Capaictors have a major impact on Analog circuits but not on Digital ones!
This is a statement that was made to me and I was asked to explain:
1. Is it true or not?
2. Explain your answer
I have no idea how to approach this, can anyone help?
  #2
Old 03-31-2009, 12:20 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Digital is usally all or nothing, so if a component is "close enough", it works.
Analog, on the other hand, is a bit like machining parts. Tolerances add up, if they add up the wrong way it doesn't fit.
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
  #3
Old 03-31-2009, 03:36 PM
mik3's Avatar
mik3 mik3 is offline
Default
In digital circuits, logic signals can be recognized as high or low bertween some voltage range. Thus, a small variation due to components tolerance is acceptable.
In analog circuits, tolerance of the components may affect the operation of the circuit at a high degree. Imagine that you design a band pass filter with a very high Q and the values of the components are not exactly as calculated due to tolerance. Because of the high Q of the filter a small variation in the components value can cause a significant variation on the bandwidth of the filter. This is an example of an analog circuit.
  #4
Old 03-31-2009, 08:17 PM
kakin kakin is offline
Default
for analog it works something like
1.1 + 1.2 + 3.1 + 1.3 + 2.3 = 9
for digital
floor(1.1) + floor (1.2) + floor (3.1) + floor (1.3) + floor (2.3) =
1 + 1 + 3 + 1 + 2 = 8
9 ≠ 8
Now imagine if that were kiloVolts, 9kV is way bigger than 8kV...
  #5
Old 03-31-2009, 09:17 PM
Kyuman's Avatar
Default
So if I understand this properly.
Even if I use a 10% tolerance Capacitor instead of a 1% the quality of the signal will not be effected nor will the quality of the product?
  #6
Old 03-31-2009, 09:27 PM
Super Moderator
Default
Depends, a lot of digital circuits have analog components. If this is the case it can matter.
In other words, only if we have the circuit schematic we can say for sure.
__________________
General info:
  #7
Old 03-31-2009, 11:59 PM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
Electrolytics have tolerances as much as -50% to +100%
To make an affordable product, the use of 10% resistors is common.
The "Hard Part" is identifying which components need to be 1%, no matter what type of component. In an oscillator or amplifier, some capacitors can be off by double with no adverse effect, others can be off by 10% and it will function poorly.
  #8
Old 04-01-2009, 08:22 AM
Kyuman's Avatar
Default
Thanks Guys, that helps clarify the answer for me
Tags
Related Site Pages
Section Title
Worksheet Class A BJT amplifiers
Worksheet Millman's theorem
Worksheet Passive filter circuits
Worksheet Ohm's Law
Similar Threads
Thread Thread Starter Forum Replies Last Post
Capacitors blocking DC Voltboy General Electronics Chat 10 05-29-2009 01:46 PM
Basic question...Capacitors and being an idiot Phsion General Electronics Chat 9 03-14-2009 10:19 PM
Physical punishment on capacitors, ect? RiG615 The Projects Forum 12 12-13-2008 01:23 AM
check resistors and capacitors raffazila General Electronics Chat 6 09-04-2008 09:41 AM
RGB contrast blooming, capacitors or resistors? Nicholas General Electronics Chat 3 07-23-2008 10:09 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
