How many LED's can be ran in series or parallel? How much power or volts would be required to run 60 LED's at once? Is there a way to run all 60 at once or would they have to be split up into 3 or 4 groups? What kind of resistors would be required to make them all run at the same brightness? Could capacitors be used to run all 60 at once or would this just blow out the circuit? Would solid state relays be a good way to good or would they serve no purpose?
