Hello Everyone,
I was hoping that you guys could help me with your expertise. I have taken the stock tail light off my bike (12v) and it has:
1 ground, 1 running, 1 brake wires (3 wires total)
My LED strip has only (2) wires total
It is just a strip of leds (9 in total)
Basically how would I make this work?
Also, I am using 2 seperate led strips, but I am going to tie them in together as I would like them to both run, and both brake (Not one strip run and the other one come on for a brake).
Also, will hooking these up to the existing wires be okay for the bulbs or do I need some sort of resistor so that they don't blow.
I really appreciate any help.
Thank you,
Russ
Thank you,
Russ
