Do I need to use magnet wire for this?
robotkid249
Joined Mar 18, 2009
24
So you might know that inductive power transfer is on the rise and there are a lot of new products using this like this battery-less mouse.
http://www.dtechnics.co.uk/images/Wirless_Batteryless mouse.JPG
Okay so anyways, I have been doing this project with its sole purpose in do some inductive coupling aka wireless power transfer. I have used arduino
arduino.cc to create a 120 khz square wave frequency.
Question one, I NEED a circuit that is very easy to build which turns Dc power into AC power using the dc source.
Here is some backround info on electro' induction. http://en.wikipedia.org/wiki/Wireless_energy_transfer
Scroll down to resonant induction.
Now second question... These two coils, do they need to be magnet wire. Or can they just be plain old copper wire.
beenthere
Joined Apr 20, 2004
15,819
Plain old copper wire, depending on you definition, is either uninsulated, or else has a much thicker insulation applied than the enamel on the magnet wire.
In the first case, the coil would simply be a dead short, and not function at all. In the second case, the coils would occupy a much greater volume than with magnet wire. The coil would be significantly less inductive due to the greater turn spacing, so the circuit would not function as expected.
Check this site for odd lengths of magnet wire - http://www.sciplus.com/.
gregdevid
Joined Feb 4, 2009
18
Hi Friend,
Yes u need to magnetic wire for your system support and also transfer to one rise and battery.
Thanks,
Parkar
DickCappels
Joined Aug 21, 2008
10,660
You can use any kind of wire. Magnet wire has the advantage of thin insulation, which means that you can use less wire to get the same number of turns in a smaller space, and that means less resistance per turn, which means higher efficiency.
