All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-22-2009, 11:47 PM
Thevenin's Planet Thevenin's Planet is offline
Send a message via Yahoo to Thevenin's Planet
Cool Emitter bias
Hello ! GMT -7
This is about the Emitter bias circuit.Since it takes positive and neegative
power supply to bias the circuit,Why shouls I have to use two supplies rather then one,since the collector voltage must be +vcc and the emitter is grounded with the negative side of a power supply.What is I missing about the positve and negative potentials.
  #2
Old 03-23-2009, 08:12 PM
PRS's Avatar
PRS PRS is offline
Default
You need to fully describe or draw the circuit.
__________________
Paul
Yakima, Washington
  #3
Old 03-24-2009, 11:04 PM
Default Emitter bias reply
Sorry for the delay,due to the fact that have no computer.
So the the circuit is a simple emitter bias circuit,that is, having a resistor attached to the collector terminal and the opppsite side connected to +vcc.The base terminal has a resistor attached to it and the opposite side of that resistor is also attached to +vcc.Which is shared by the collector resistor.The emitter terminal is connected by a resistor and its opposite end is connected to the Negative side of a second power supply and this second power supply positive side is grounded.
So why can I not use one supply since the Emitter is connected to a negative polarization. What's happenning? More current or what.
GMT -7
  #4
Old 03-24-2009, 11:12 PM
kakin kakin is offline
Default
if i understand you description correctly, the second supply is shorted to itself.. the other explanation would be that the second supply effectively lowers the bias voltage, for example if Vcc = 5v and Vs (second source) = 1v you have an effective 4v at the base.
I may be wrong, little rusty on analog.
  #5
Old 03-25-2009, 03:18 PM
PRS's Avatar
PRS PRS is offline
Default
Your transistor is set up correctly and so is your supply. I'm not sure if this is a school project or your own experiment. If the former, your forced to use what is called a 'two-ended' supply because it's an assignment. If you're just experimenting, you can use a single ended supply.
To do this get rid of the 2nd supply altogether. Now ground is the negative lead on your supply and Vcc is the high side. Hook the collector resistor to Vcc, the emitter resistor to ground and your base resistor to Vcc -- just as before. But most amplifiers use two resistors at the base. These are in series between Vcc and ground. This forms a voltage divider with which to bias the base.
In short, yes, one supply works.
__________________
Paul
Yakima, Washington
  #6
Old 03-25-2009, 08:43 PM
Default emitter bias image
This is the circuit config.
  #7
Old 03-25-2009, 08:49 PM
PRS's Avatar
PRS PRS is offline
Default
Now you've got +Vcc and -Vcc and also ground. This circuit is very nice. I wish I had the facility to draw you a circuit with the same configuration but with only one source, but I do not. Perhaps someone else in this forum will do it for you.
__________________
Paul
Yakima, Washington
  #8
Old 03-26-2009, 05:56 PM
Red face Biased emitter mystery
Hello again !
The homework is attempting to understand what make electronic works. Regarding Kakin , I am assuming that you are thinking of a feed back circuit for controlling the bias point.PRS if I do what you suggested it seem to become
the common emitter bias.But the circuit suppose to have the intention to keep a constant current.Referring to the mysterious grounds or should I say the interchangeable concepts OF GROUNDS,but one of the main question is that the Ground on the above thread,is Rb grounded to +Vcc or -Vee. If its grounded to +Vcc then its what the frist post I made.If its grounded to the -Vee,then it seems to be a grounded base circuit ? My third intuition is that two batteries in series connection and the Rb is grounded between the connection where the two batteries positive and negative are connected leaving the two opposite end which is positive and the other negative polarity.Which having the positive end connected to the +Vcc and the other end of the series battery that is negative connected to Re end. Frist where is the ground connected ANYBODY.
P.S. kAKIN THAT bLOG OF YOUR GOING TO BREAK SOMEBODY MACHINE
GMT -7
  #9
Old 03-26-2009, 08:18 PM
PRS's Avatar
PRS PRS is offline
Default
Like you said, you hook up your two batteries in series -- as you described -- and the connection between them is the ground. Connect Rb between the base and that point. The whole circuit sees this point as ground.
The circuit is a generic one as you can input a signal at the base and take the output off either the collector or the emitter. And if you put a capacitor from base to ground and input at the emitter it is also a CB amp. Without that it is either a CE or a CC amp.
CE or CC amps can be considered constant current sources, controlled by the voltage at the base. That's why the gain parameter gm is transconductance.
If you want to find the current do a KVL loop around Rb, Vbe and Re and -Vcc. If you need help on this let me know.
__________________
Paul
Yakima, Washington
  #10
Old 03-29-2009, 11:31 PM
Default Emitter bias constant "I"
Hi !
I am assumming that a constant current has a specific amount of current that will not damper under a significant amount of current drain. A good analogy would be a large reservior.The water flow would not decrease or damper out because of the the large magnitude regrading a large draint of current . I am assumming again, that is why the battery is placed in the emitter,to get that magnitude.This is leading to the circuitry of the Long tail pair Differential amplifier. I become to know that is a very important circuit in the digital intergrated circuitry.So I figure I would start from the derivative of the circuit,the Emitter bias. Besides,it seems that it can be modified to be use as another important circuit,the Upper and lower comparator in the 555 timer.But there seems to still be a discretion of confusion, and is differial amplifier if splitted into halve the base will be connected to Vcc and the emitter to the second battery nagative potential. As I was describbing in the orginal post of this thread.I did can more understanding about the ground connection,Which seems to puzzle me alot when looking a schmatics of photo facts.
Tags
Related Site Pages
Section Title
Worksheet Class A BJT amplifiers
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Feedback : Bipolar Junction Transistors
Textbook Biasing calculations : Bipolar Junction Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Textbook The common-base amplifier : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Bipolar junction transistors : Solid-state Device Theory
Textbook The NOT gate : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
BJT Emitter to Collector current in linear mode, how? SiegeX1 General Electronics Chat 9 03-12-2009 05:14 AM
Collector - Emitter Bias Calculation Help sparkey2000 Homework Help 1 08-06-2008 08:01 PM
dc bias of a common emitter amplifier confirmguy General Electronics Chat 3 10-10-2007 10:03 PM
emitter base collector bias Unregistered Feedback and Suggestions 3 08-08-2007 08:50 PM
help in transistors zeerum Electronics Resources 4 04-15-2007 10:11 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
