All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-17-2009, 01:55 AM
hitmen hitmen is offline
Default Designing a 16-4 priority encoder from 2 74148 8-to-3 line priority encoder device
Hi all,
My tutor gave me an answer I did not understand.
I searched the datasheet of 74148 but it did not specify what is GS, E0 and E1.
I also do not understand why the E1 of one 74148 is connected to the E0 of another.
Can anyone help?
  #2
Old 03-17-2009, 02:04 AM
beenthere's Avatar
beenthere beenthere is offline
Default
All you have to do is look at the truth table to see what conditions set GS low and EO low. You can also see the effect of the EI^ input (hint - when it is high, what happens to the outputs, including GS^ and EO^?).
__________________
First comes the hardware, then the software.
  #3
Old 03-24-2009, 10:25 AM
Default
Well, I got the answer from my tutor but there is one thing I dont understand. What does GS stands for?
I learnt from my tutor that:
1) The IC that displays the MSB have to be disabled if it is below a certain level.
2) The outputs from each gate have to be AND together to produce the desired output.
I know that E is enable while I0 to I7 are the inputs while thost starting with A are the outputs.
And I still dunno what GS stands for?
  #4
Old 03-24-2009, 11:22 AM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
GS is "Group Output" - goes low on priority detect, with priority address in A0-3, also active low, combined with GS to flag which IC when cascading two.
  #5
Old 03-24-2009, 12:05 PM
beenthere's Avatar
Default
Googling "74148" will let you find a data sheet for the device.
__________________
Tags
Related Site Pages
Section Title
Worksheet Basic algebra and graphing for electric circuits
Worksheet Analog-to-Digital conversion
Worksheet Digital-to-Analog conversion
Worksheet Memory devices
Worksheet Encoders and decoders
Worksheet Digital codes
Textbook Network protocols : Digital Communication
Textbook Flash ADC : Digital-analog Conversion
Textbook Encoder : Combinational Logic Functions
Textbook Decoder : Combinational Logic Functions
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
