All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-12-2009, 09:14 PM
rajeshbro rajeshbro is offline
Default Voltage drop in three phase bridge rectifier
Does anyone know how much voltage is dropped when rectifying a three phase AC Voltage into DC Voltage. I know its 2 times the diode forward voltage drop for 2 phase rectifier but wasn't sure for 3 phase rectifier.
For, eg, for 10 VAC RMS rectifying using bridge rectifier with 0.7V forward voltage drop for each diode, you will have total voltage drop of 1.4V (2 times 0.7). But would be the formula for 3 phase rectifier where 6 diodes is used?
Thanks you.
  #2
Old 03-18-2009, 02:10 AM
t_n_k t_n_k is offline
Default
In principle with the 3-phase equivalent of a single phase rectifier bridge there are still only two series diodes conducting in any particular part of the AC cycle.
There is a condition - commutation interval - during which three diodes are momentarily conducting (not all in series). The latter is probably not of interest or necessary to consider in a simple design case.
There are certain poly-phase rectifier circuit options in which only a single diode drop is encountered. For rather more specialized applications.
Tags
Related Site Pages
Section Title
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Special-purpose diodes : Diodes And Rectifiers
Textbook Zener diodes : Diodes And Rectifiers
Textbook Diode switching circuits : Diodes And Rectifiers
Textbook Voltage multipliers : Diodes And Rectifiers
Textbook Clipper circuits : Diodes And Rectifiers
Textbook Peak detector : Diodes And Rectifiers
Textbook Rectifier circuits : Diodes And Rectifiers
Textbook Introduction : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
A three phase bridge inverter with Y(star/wye)-connected load? lihker Homework Help 0 12-24-2008 03:44 AM
Need help with Full wave bridge rectifier circuit alialiali Homework Help 2 12-13-2008 02:25 PM
To calculate Phase angle or phase difference between voltage & current. rvb53 Homework Help 11 06-17-2008 04:13 PM
split phase power shmerd General Electronics Chat 3 05-21-2005 01:59 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
