All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-05-2009, 10:16 AM
picstudent's Avatar
picstudent picstudent is offline
Member
Default How to use Decoupling capacitors for Op amp in dual rail
Hello
I have op amp OP07 and TL084 in a board. Some 2to 30 in a board with a MCU onboard.
How to provide the decoupling capacitors for these op amps. +12 and -12 are supply rails?
We need to decouple both rails or one is needed? How the the optimum value is decided?
  #2
Old 03-05-2009, 10:28 AM
mik3's Avatar
mik3 mik3 is offline
Default
Put a 100nF capacitor between the +ve rail and ground, another one between -ve rail and ground and one between +ve and -ve rails.
  #3
Old 03-05-2009, 11:31 AM
picstudent's Avatar
Member
Default
Quote:
So three non polar capacitors .1uF for each op amp. I have some 30 op amp in a PCB. So huge part count.
What is really the function of de copupling capacitors in Op amp circuits? What are the consequences in general if not provided?
  #4
Old 03-05-2009, 12:38 PM
gotumal's Avatar
gotumal gotumal is offline
Member
Default
Any IC consume power depending on the output load condition (drive power). So when load curent increases suddenly, a voltage dip may occure at the power pins of IC. During that time, decoupling capacitor provides the enough charge not to have voltage dip.
Depending on freqency of operation (analog, digital (in KHz, MHz)) value can be decided like 0.001µF, 0.01µF, 0.1µF etc.
__________________
- Gotumal
"I always win, except when I loose. But then I just don't count"
  #5
Old 03-05-2009, 03:00 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Well, actually - just two 100nF nonpolarized caps per opamp.
One from Vcc to ground, and one from Vee to ground, as close to the supply pins as you can.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #6
Old 03-05-2009, 10:29 PM
mik3's Avatar
Default
Well, with op amps, if you have a good low noise power supply you don't really need decoupling capacitors because they don't switch rapidly and cause noise on the pcb tracks.
  #7
Old 02-09-2012, 09:04 PM
davidgrahamsites davidgrahamsites is offline
Default
Why the extra between V+ and V-? Is this in case of a fast transition between upper and lower voltage rails with a signal carrying a higher load?
  #8
Old 02-09-2012, 09:53 PM
crutschow's Avatar
crutschow crutschow is online now
Default
Not entirely true. The decoupling is not to prevent noise on the power rails, it's to stabilize the op amp. Some op amps (especially higher frequency ones) will become unstable or show deviations in their frequency response if their power rails are not properly decoupled.
__________________
Zapper
Curmudgeon Elektroniker
  #9
Old 02-09-2012, 09:57 PM
crutschow's Avatar
Default
Quote:
If the power rails are properly decoupled to ground, then you shouldn't need the third cap. The power rail AC currents are from each rail to ground through the output load (plus or minus rail depending upon whether the output polarity is positive or negative), so the primary currents to be decoupled are from each of the rails to ground, not between rails.
__________________
Zapper
  #10
Old 02-09-2012, 11:00 PM
ErnieM's Avatar
ErnieM ErnieM is offline
Default
Caps are damn cheap. Add then every place (even that third cap) if you are laying out a PC board. If you find you don't need them all you just don't populate some spots.
Quote:
I've never had cause to need that third cap either.
Sure, leave em out, if you don't mind extraneous oscillations and other weird artifacts.
__________________
“Freedom is never more than one generation away from extinction. We didn’t pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children’s children what it was once like in the United States where men were free.”
Tags
Related Site Pages
Section Title
Worksheet CMOS logic gates
Worksheet Performance-based assessments for analog integrated circuit competencies
Worksheet Design Project: audio media-based signal generator
Worksheet Negative feedback opamp circuits
Worksheet Basic operational amplifiers
Worksheet Electrical noise and interference
Textbook Practical considerations : Operational Amplifiers
Video Lecture Op Amps Characteristics (Part 4) - Common vs. Differential - Op Amps and Op Amp Circuits
Video Lecture Linear Transistor Applications - Transistors and Transistor Circuits
Textbook High-impedance voltmeter : Analog Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to select decoupling capacitors sharath_412 General Electronics Chat 8 01-26-2009 11:00 PM
LF357 dual op amp kahafeez The Projects Forum 4 01-16-2009 03:08 AM
Building a dual rail supply from a 64VCT trans kevinwil General Electronics Chat 1 02-23-2005 03:10 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
