Hi i have this relay on a PCB i understand how the DPDT relay works but i am struggling with the connections to the PCB could anyone help.Here ia the PCB attached.
The center (composite) image of the board is the key to the whole thing.
I've enlarged it and added some notes around the edge:
What's not obvious is which common terminal relates to which set of NO/NC contacts. I've added jumpers on the bottom as to what makes the most sense, but you'll need to verify by using a meter from the NC terminals to the common terminals on the bottom.
