All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-27-2009, 07:15 PM
jordanwb jordanwb is offline
Junior Member
Default Red wire or the black wire?
I have an ancient laptop (Toshiba T4400C) that I want to get going. Inside it there are two batteries. One is dead and one I lost. The one that is dead can be rebuilt, I can make a makeshift battery for the one I lost out of AAA batteries instead of AAAA batteries. The battery pack connects to the motherboard with a small connector that goes on only one way. One wire is black and one is red. Would I connect the black wire to the positive and red to the negative or the other way around?
  #2
Old 02-27-2009, 07:24 PM
jpanhalt jpanhalt is online now
E-book Developer
Default
In DC, red is usually positive and black is negative. Do you have an ohmmeter? If so, the black should be ground, so to confirm the assignment, see if the black lead is connected to the ground plane, attachment screws, etc. on the PCB.
John
John
  #3
Old 02-27-2009, 07:35 PM
Junior Member
Default
I touched the black lead of my ohmmeter to ground and the red lead to the red wire. There was a flow for a short period of time (~half a second). I moved the red lead to what would be the black wire and I got continuous flow.
  #4
Old 02-27-2009, 07:41 PM
beenthere's Avatar
beenthere beenthere is offline
Default
The brief conduction through the red lead was due to capacitors charging. The black lead is circuit ground.
__________________
First comes the hardware, then the software.
  #5
Old 02-27-2009, 07:44 PM
Junior Member
Default
I tried it again, and I got different results. With the black lead to ground and the red lead to the red wire it read 751 ohms but with the red lead to the black wire it read 1 ohm. So would that mean I'd connect the negative of the batteries to the red wire?
[Edit] The change in results was because before I had it set to read up to 200 ohms, the second time I set it too read up to 2000 ohms, which caused the change of results.
  #6
Old 02-27-2009, 08:02 PM
studiot's Avatar
studiot studiot is online now
E-book Developer
Default
Ask here
http://home.att.net/~ronkar/toshiba.html
__________________
Do I look old?
I don't feel old.
I don't feel anything till noon.
Then it's time for my nap.
  #7
Old 02-27-2009, 08:30 PM
Junior Member
Default
Quote:
Originally Posted by studiot View Post
I'll take a look at that thanks.
Tags
Related Site Pages
Section Title
Video Lecture Inductors (Part 3) - Troubleshooting - Inductors,Capacitors,Transformers
Textbook Basic voltmeter use : Worksheet
Textbook More on AC "polarity" : Complex Numbers
Worksheet Kirchhoff's Laws
Worksheet Basic ohmmeter use
Textbook Meter check of a diode : Diodes And Rectifiers
Textbook Current divider : Dc Circuits
Textbook Potentiometer as a voltage divider : Dc Circuits
Textbook Power dissipation : Basic Concepts And Test Equipment
Textbook Multimeters : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Very simple EFIE circuit help...Im a beginner mrbriteside1465x2 General Electronics Chat 8 09-29-2010 12:21 PM
Shock Current Path Question mako General Electronics Chat 36 01-11-2009 02:24 AM
project problems??? Mathematics! The Projects Forum 18 08-01-2008 09:11 PM
Why is there no GND on my DC Powersupply? cds333 General Electronics Chat 25 11-10-2007 06:05 AM
Electromagnetism AWSariti General Electronics Chat 3 01-05-2005 09:38 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
