All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-24-2009, 06:21 PM
fearnofish420 fearnofish420 is offline
Default Best way to DIM Led Strip?
I need to be able to Dim 2 Led Strips that I have connected to a 12v Battery. I was wondering what is the most efficient/simple way to achieve this? If anyone could possibly point me in the direction to a schematic or a type of circuit that would be able to preform this operation.
Thank You to anyone with some input!
  #2
Old 02-24-2009, 06:47 PM
bertus's Avatar
bertus bertus is offline
Administrator
Default
Have a look at this thread where SgtWookie made a simple PWM circuit.
http://forum.allaboutcircuits.com/showthread.php?t=9016
Greetings,
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 02-24-2009, 06:56 PM
italo italo is offline
Banned
Default
LEDS are not exactly linear devices a minimn voltage must be present and a minimumn current must flow. Having point that out the best way to control LEDS are by controlling the current. If you controll the current then the voltage requirement is immaterial. the best chip to do that cheap and easy is the lm317 1.25 v voltage regulator. the design is simple assume a max current of whatever the LED can sustain withing the power consumption and add a resistor 50Ω [20 ma] and a pot of 50 Ω [1.25 ma] in series from adj to output. These value are examples of current. Too complicated then measure the voltage source and add a variable resistor in series that will get the same results.
  #4
Old 02-24-2009, 10:09 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Quote:
I really wish that you would stop replying to threads until you know what you are talking about.
The "information" that you have provided is very easily misleading and potentially very confusing to newcomers.
If the original poster's LED "strips" are rated for operation at 12v, they will not work with an LM317 regulator configured as a current regulator. In such configuration, LM317's have a minimum 3v drop from input to output, which would prevent our OP's LEDs from lighting at all.
Most LED ropes or "strips" rated for 12v have built-in current limiting or regulating circuits. For this particular application, PWM is clearly the way to go.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 02-24-2009, 11:25 PM
Default
There is so much information on PWM and 4093 Schmitt input NAND gate. Where is a PWM schematic that I would be able to replicate to create an led dimming circuit?
Thanks for all you help and patience with me. Believe it or not I actually graduated recently as an electrician but very little was taught about electronics and PWM. I understand the 555 timer but as far as other parts needed to make it work that I am not sure of.
Thanks again to all
  #6
Old 02-24-2009, 11:48 PM
Default
This is what I have made and It does not work. All that happens is the light strip pulses extremely fast. I move the potentiometer very minimal and only see it fluctuate its pulse. Nothing dims what so ever. I have put this circuit onto a breadboard and have tried to make it dim with no results I dont know if its the values I have or the wrong type of components but your knowledge is greatly needed. If it helps anyone figure this out I used electronics workbench to create this schematic.
  #7
Old 02-25-2009, 02:21 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Before you go any further with your design you need to calculate a current limiting resistor to put in series with your LED. Otherwise the LED and/or the transistor will be damaged.
hgmjr
  #8
Old 02-25-2009, 03:23 AM
SgtWookie's Avatar
Expert Member
Default
This thread is basically a duplicate of a thread in the Projects Forum:
http://forum.allaboutcircuits.com/sh...ad.php?t=19485
I've responded in the other thread about inconsistencies in our OP's schematic; in particular the mislabled 555 timer pins, and posted a circuit using a 555 timer that should do what our OP wants to do.
__________________
General info:
Tags
Related Site Pages
Section Title
Textbook Building simple resistor circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Pls help me.Need advice ridge84 Embedded Systems and Microcontrollers 4 11-29-2009 09:35 PM
LED Lighting. I need some design and theory help. Tom Kay The Projects Forum 19 03-04-2009 03:19 PM
Dimming LED Strip with 555timer fearnofish420 The Projects Forum 9 03-03-2009 08:06 PM
Help! LED modules with certain strands going dim?? Chikan The Projects Forum 22 10-18-2008 07:55 PM
LED Dimming in Parallel pfhorge The Projects Forum 6 02-27-2007 07:36 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
