All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-22-2009, 04:14 AM
jpietrowiak jpietrowiak is offline
Default How to Test DC motors?
How do you test DC motors with a meter. Is there anyway to test overall contact with the brushes. I've tested AC motors with a megger. Does the same apply?
  #2
Old 02-22-2009, 05:15 AM
b.shahvir's Avatar
b.shahvir b.shahvir is offline
Default
Quote:
I think a DMM (in ohms or continuiy test mode) would work fine for contact with brushes. A megger is always best for insulation test of machines.
  #3
Old 02-22-2009, 05:22 AM
Default
I assume then checking to ground on the motor would be the same. What about between leads like on a standard motor? Also i heard someone say once that they connect all the leads together then perform some sort of test. I always on AC motors just test each lead to ground instead of trying to tie them all together. What are your thoughts?
  #4
Old 02-22-2009, 07:11 AM
jpanhalt jpanhalt is offline
E-book Developer
Default
I have seen DC armatures tested with a "growler." Here is an interesting link describing testing DC motors. The use of a growler is several pages deep.
John
  #5
Old 02-22-2009, 01:44 PM
Default
Not sure I follow it completely. Where do you put your meter leads. Do you remove the brushes and put your leads into the whole? Perform tests from the wires? Leave brushes in and hold them there and test? or do you have to rip apart the entire motor to test?
  #6
Old 02-22-2009, 03:06 PM
b.shahvir's Avatar
Default
My best bet is still Megger & DMM........ sticking to simple procedures is my opinion
  #7
Old 04-07-2009, 12:16 PM
Douglas Chin Douglas Chin is offline
Default Testing DC Motors
I have been working with DC motors ,drives etc for over thirty years. Whilst using meter and megger meters check out the continuty and grounds it cannot really check a DC motor out propelly. What I have done is actually built a test jig to apply actual voltages to both field and armatu,re. The motor must be uncoupled from the load. As a result, the motor turn. However, one must be very careful in doing this test.
How about those SCRs? Do not use a megger on SCRs!!!. An ohmeter can find somefaults. Again, I have built a jig to test in an active mode and by turning a pot , the scr can be made to be turned on ligtly or heavily.
Passively checking items is not 100% acurate.
Douglas
  #8
Old 05-19-2009, 06:17 PM
Default
When you say SCR's are you talking about the ones in the drive or are there some in the motor itself.
  #9
Old 12-05-2009, 12:51 AM
docgoo docgoo is offline
Smile
scrs are usually found in drives.
  #10
Old 12-05-2009, 03:27 AM
BillB3857's Avatar
BillB3857 BillB3857 is offline
Default
Check out this link.......http://www.eswtesters.com/documents/...d%20motors.PDF
Tags
Related Site Pages
Section Title
Worksheet Design Project: DC motor
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook High voltage ohmmeters : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Capacitor Start motors keelezibel The Projects Forum 6 01-31-2009 05:35 AM
PWM Controller for giant antique 20+ HP DC motors? DMahalko The Projects Forum 7 10-27-2008 11:53 PM
How to test pulse width modulator circuit without Oscilloscope naitek General Electronics Chat 3 06-10-2008 08:21 AM
Test Rig Construction Steve1992 The Projects Forum 3 02-17-2007 05:35 PM
Electronic test set question AHMARAFAH General Electronics Chat 1 01-23-2007 02:16 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
