All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-31-2005, 04:14 AM
Surendar Surendar is offline
Junior Member
Default
What is Current to voltage converter and Voltage to current converter.How it can
be used for applications.
Thank you
Regards,
Surendar
  #2
Old 01-03-2006, 02:10 AM
Murod Murod is offline
Junior Member
Default
Current to voltage converter is a circuit that makes a current source becomes a voltage source. Voltage to current converter is a circuit that makes a voltage source becomes a current source.
A voltage source is a point that gives a specified voltage regardless the impedance of the load. A voltage source will give the specified voltage on load with various impedance, so the current will vary according to the load's impedance.
A current source is a point that gives a specified current regardless the impedance of the load. A current source will give the specified current on load with various impedance, so the the voltage will vary according to the load's impedance.
One example of current to voltage converter is the circuit in light intensity meter using photovoltaic sensor. Because the sensor acts like a current source proportional to light intensity, a current to voltage circuit will make the response to be linear. You can't get a linear response if you treat the sensor as a voltage source.
One example of voltage to current converter is in the circuit for transmiting signal for long distant. If you use a voltage signal, the receiver will suffer a voltage drop on the signal. If You use a current source, You won't. It is widely used in industrial instrumentation for communication between sensor system and the controller, or between controller and the actuator.
  #3
Old 05-27-2009, 06:47 AM
sreejisreeni sreejisreeni is offline
Default
I would like to ask you to refer "Operational Amplifiers and Linear ICs(Desing&trouble shooting)" by David A Bell, for nice design of V-I & I-V converters using opamps..
  #4
Old 05-27-2009, 07:00 AM
bertus's Avatar
bertus bertus is online now
Administrator
Default
Do you realize this thread is from december 2005.
The OP will be gone long.
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
Tags
Related Site Pages
Section Title
Worksheet Linear computational circuitry
Worksheet Class A BJT amplifiers
Worksheet Elementary amplifier theory
Worksheet Th'evenin's, Norton's, and Maximum Power Transfer theorems
Worksheet Resonance
Textbook Resonant filters : Filters
Textbook Voltage-to-current signal conversion : Operational Amplifiers
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook The common-emitter amplifier : Bipolar Junction Transistors
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Capacitor charging at Converter Output jpborunda The Projects Forum 8 06-02-2014 09:41 PM
Buck converter and Boost converter porky67 General Electronics Chat 12 12-09-2010 04:39 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
