All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-14-2009, 04:41 PM
tabbo66 tabbo66 is offline
Default holding circuit
im still not sure how to wire a holding circuit. i know to bring the 120v into the stop btn and back out into my start btn from there i go up to my contactor, from the contacts cr1-1 do i bring both wires back into the n/o switch.on our trainer the start btn has 2 n/o contacts one is energized and the other side is the side i want to parallel in to create my holding . also is there a web site i can go to that will break the wiring down an explain all of the processes of wiring?
  #2
Old 02-15-2009, 02:35 AM
mik3's Avatar
mik3 mik3 is offline
Default
Do you want to make a latch circuit by using a relay?
  #3
Old 02-15-2009, 03:07 AM
leftyretro's Avatar
leftyretro leftyretro is offline
Default
This should help. Standard motor starter wiring uses latching to allow momentary start and stop push-buttons.
http://www.sea.siemens.com/step/temp...mponents:3:2:8
Lefty
__________________
Measurement changes behaviour
  #4
Old 03-17-2009, 10:51 PM
ECM ECM is offline
Default
I'm designing a circuit in my head for a pump start on a irrigation system. The pump will have a low flow switch on the discharge side, that will open and stop the pump if it should run dry. I may put a pressure switch in as well. The problem is that the pump must start and run long enough for the water flow to close the low flow switch to create the holding circuit.
I was thinking of using a timer relay that I can energize for the set amount of time needed to bring the pump up to capacity. The NO contacts of the timer relay would be paralleled to the low flow switch. Then when timer relay times out the flow switch should complete the circuit and keep the pump running until the irrigation controller turns off the pump run signal, or the flow switch opens.
The biggest problem I have is that the irrigation controller puts out a 24 VAC signal, the timer relay, and motor start relay that I have use a coil voltages of 120VAC. I do have a 24 V coil cube relay that I can use one set of NO contacts to energize the timer, and the other set of NO contacts to complete the circuit through the flow switch and and starter relay with 120 V. I will also add a bypass switch, so that I can run the pump without the flow switch timer relay and so on, for trouble shooting, should a problem ever arise.
What I was wondering if anyone has designed a circuit like this or might have any suggestions or a maybe even a schematic?
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Latch circuits
Worksheet Electromechanical relay logic
Worksheet AC motor control circuits
Textbook The S-R latch : Multivibrators
Textbook Programmable logic controllers : Ladder Logic
Textbook Fail-safe design : Ladder Logic
Textbook Motor control circuits : Ladder Logic
Textbook Permissive and interlock circuits : Ladder Logic
Textbook Time-delay relays : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
Total Resistence in Parallel circuit AWSariti General Electronics Chat 14 02-27-2009 11:44 AM
Holding circuit for magnet control Crane Guy Homework Help 10 01-18-2009 10:57 PM
LOW VOLTAGE Circuit TESTER lamps relicmarks General Electronics Chat 5 11-03-2008 12:32 AM
Sensor circuit, Flasher circuit 123456 Homework Help 11 08-03-2006 10:58 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
