Hi, I am converting an old ATX PSU into a lab PSU. As I understand it I can get 24V out it by using the -12 and +12, giving me the range, or close to it.
Because -12 will be treated as ground does the max amps for the specs still stand or are the specs only rated against ground?
Also it's recommended that you put at least a 10W 10 Ohm resistor between a +5 wire and a ground wire 'or else your PSU you may not stay on'. Ive never had this problem, never used a resistor and been using computer PSUs for a few years to run other things, for example router, modem, phone charger and additional fans as a single source. I just short the green + a ground. A PSU I am about to be experimenting on though says its 5V 2.5A-40A. Does that mean I should get a 15W 5 Ohm res to bring it up? 12.5 with 2 Ohms being the exact values needed, I think ... I get the feeling Im looking at this resistor problem wrong, once I pick it up though I should be fine, so please any input at all that will help.
Thanks.
Thanks.
