All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-09-2009, 08:57 PM
Gdrumm's Avatar
Gdrumm Gdrumm is offline
Default What is infinite resistance?
I'm trying to solve a series circuit question from my DC Circuits class homework, and I can't seem to recall what infinate resistance means.
Here is the info I have on the circuit.
E=40v, R1=5ohms, R2=10ohms, R3= Infinate ohms.
I see the answer in the back of the book, but I don't know how they got it.
I'm solving for E Total, I Total, R Total, and P Total.
I'm guessing that infinate resistance means there is a short?
Thanks, Gary
  #2
Old 02-09-2009, 09:01 PM
KL7AJ KL7AJ is offline
E-book Developer
Default
Thanks, Gary
Nope...infinite resistance means the component (resistor) does not exist. You may safely remove it from your schematic with no danger of punishment
__________________
REAL men don't need voltmeters.
  #3
Old 02-09-2009, 09:55 PM
Gdrumm's Avatar
Default
Thanks,
But I'm still curious, because in the answer section of my workbook, it shows Total I=0 amps, meaning that R3 in effect neutralized R1 and R2.
So, does this look accurate?
ET = 40v
IT = 0A
RT = 00 ohms
PT = 0 watts
What does "fail open" mean?
I found that on this site, Vol 1, Chapter 5/7.
It implies that a resistor might "fail open", increasing it to near infinate levels.
Thanks, Gary
  #4
Old 02-10-2009, 12:28 AM
mik3's Avatar
mik3 mik3 is offline
Default
If the resistors are connected in series then no current will flow due to the infinite resistance (open circuit).
if the resistors are connected in parallel then current will flow only through R1 and R2.
  #5
Old 02-10-2009, 12:55 AM
flat5 flat5 is offline
Default
"fail open" means resistor has been destroyed. It has failed.
In this case, "fail open", it does not pass any current anymore.
It is a dead resistor. Don't try to return it to the store where you bought it.
See "Monty Python Dead Parot Sketch".
http://www.youtube.com/watch?v=e6Lq771TVm4
  #6
Old 02-10-2009, 05:11 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
I=E/R, so as R increases, I diminishes. As R increases without bound, I approaches zero. Once R is a few zillion yotta-Ohms, I is a few zillionths of a yocto-Ampere.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
  #7
Old 02-10-2009, 02:06 PM
blhoward's Avatar
blhoward blhoward is offline
Default
Thanks, Gary
Infinite resistance is open circuit (burnt resistor in real life) no current will flow, zero ohms is short circuit.
Lets not confuse.
Brian
Tags
Related Site Pages
Section Title
Worksheet Active loads in amplifier circuits
Worksheet Class A BJT amplifiers
Worksheet Th'evenin's, Norton's, and Maximum Power Transfer theorems
Textbook Simple parallel (tank circuit) resonance : Resonance
Textbook Basic identities : Algebra Reference
Textbook Voltage and current calculations : Rc And L/r Time Constants
Textbook Battery construction : Batteries And Power Systems
Textbook What is network analysis? : Dc Network Analysis
Textbook Ohmmeter design : Dc Metering Circuits
Textbook Component failure analysis : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
resistance of water whale General Electronics Chat 8 02-04-2009 08:53 PM
How to calculate the input resistance for the following? thenzengineer Homework Help 5 04-12-2008 09:53 PM
Nonconstant Resistance (newb) Question Ippocrate The Projects Forum 12 07-19-2007 03:38 PM
Reversing resistance? amc The Projects Forum 3 04-24-2007 05:52 PM
thevenin resistance question phenohm Homework Help 6 11-27-2006 04:38 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
