Hey all, this is my first post here. I'm working on a project and was wondering if I could get any feed back, so here it goes:
The idea:
I'm trying to use a PIC 16F84A to convert the serial output of an NES controller to parallel outputs on 8 pins of the PIC (I will then use these and an old USB keyboard controller board to send the inputs to my PC).
NES controller background:
The nintendo deck sends a 12us pulse down a wire called the "Latch" to the controller. This tells the 4021 shift register in the controller to store all the button states. After this 12us pulse the controller pulses the "Data" wire of the controller either high or low. If low, the A button is pressed. The nintendo deck then pulses high 6us down a "Clock" wire, then low 6us. This process is repeated for every button. The controller pulses low on Data for a button press, high for the button not being pressed. The pulses are always in this order: A B Select Start Up Down Left Right.
(More info can be found here if im not clear enough: http://web.mit.edu/tarvizo/web/nes-controller.html)
My approach:
Here is a diagram of what my circuit will look like. I will be using 5 volts for VDD.
I have attached a text file of the code I have written. To account for the 12us and 6us delays the controller is expecting, I will need some sort of delay loop. I haven't written these in yet, but comments are present where the delays should be. Basically my code begins by pulsing the Latch, then reading the first Data pulse. Then the 7 Clock pulse and Data reads take place. With every read, the value of data is stored in a defined STORAGE register, which is then read after the clocking and the proper pins are given high pulses on the PIC to send out to the USB keyboard.
So I guess my first question is will this work/is this plausible? If so, any recommendations on what kind of crystal I should use to clock the PIC? I really appreciate any feedback and please let me know if I can clarify anything that isn't clear. Thanks!
NOTE: The nintendo deck does this whole algorithm every 60hz.
Thanks for reading!
The idea:
My approach:
Thanks for reading!
